74 factory AC
Old Aug 22, 2021 | 11:33 AM
blackelim's Avatar
blackelim
74 factory AC
I am in the middle of re-installation of factory air on my truck. The prior owner removed everything so I have been acquiring parts to replace the system. I have parts from 2 different years and I have a question on how the expansion valve bulb is clamped to the low pressure side. The evaporator coil I am using has 0 ring fittings, the low pressure side tubing is very large. I think it is a #10 size. Can someone post a picture of the expansion valve area? I have searched but have not found a picture yet. Also how about an overall of A/C hose routing so I can route them correctly?
Thanks
Does this look correct?
Old Aug 22, 2021 | 12:20 PM
redroad's Avatar
redroad
Have a look only just a few threads back "I have searched but have not found a picture yet."
Old Aug 22, 2021 | 12:26 PM
Flecker's Avatar
Flecker
My 74 has a completely different set up that yours... not sure how helpful it is.
Old Aug 22, 2021 | 01:42 PM
tbear853's Avatar
tbear853
Mine is a mix of 1973 and 1979 parts, '73 controls and heater core, but remainder was taken from a '79. I hope it helps. Chart is labeled '78 Bronco, but looks right from here.
Last two pics are just some I saved from somewhere, might shed a light. I think what "OP" is asking is under a wrap of insulating material in the chart and on my truck.
Pardon the pine needles ... this was a couple-few years ago. Yes, I run an air filter too.
Old Aug 23, 2021 | 08:33 PM
blackelim's Avatar
blackelim
Thanks
Ok, next question,
In the picture above the low side hose fitting is i believe a No. 12 male o-ring fitting. It's huge, What is the best way to convert this to the more common fitting size (like on the Sanden compressor) think is a
No.10?
I am installing a Sanden compressor.
Old Aug 23, 2021 | 08:54 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Ok, next question,
No.10?
When I did the Sanden conversion I had new hoses made. They used new fittings on the compressor end and on the drier and evaporator ends the shop cut the original ends off the old hoses and braised them to new hose fittings. This is a common repair when the hoses have "weird" ends on them.
Old Aug 23, 2021 | 08:58 PM
redroad's Avatar
redroad
Call these guys and tell them what you're doing.
Old Aug 23, 2021 | 10:40 PM
440 sixpack's Avatar
440 sixpack
Original Air has a Sanden conversion kit that takes care of all this and the price is reasonable. if you don't want the whole kit they might sell you just the parts you need.
Or as others have said just get custom hoses made up if you can find the correct ends. replace the expansion valve and cover it with tacky tape as well.
paker
1997 - 2003 F150
May 5, 2021 07:10 PM
bigperm2
Feb 28, 2016 06:53 AM
Jonnys.1991
Aug 25, 2015 10:27 AM
RNOVRIT
Aug 27, 2007 12:25 PM
chiefrene
Aug 31, 2003 06:26 PM
