Air conditioning retrofit, AC gurus please help!!
First of all, I beg of anyone on here, for gods sake, never piece together an air conditioning system. The $1500 or so it cost for the aftermarket kits is worth it!
So, quick background. I bought my truck with a dealer installed AC in the cab. The type of AC that has the vents in the dash. P.O. removed everything under the hood including the condenser. I have installed from a factory AC junkyard truck, the condenser, dryer (will be replaced) and AC brackets. I have a new sanden compressor and expansion valve and will be converting to R134A. I am in the process of building new AC lines.
First, please correct me if I am wrong. The order of flow is....
Compressor>condenser>Dryer/receiver>Expansion valve>Evaporator>Suction side of compressor. The only reason I ask is that I have seen a few diagrams on the internets where the dryer is before the condenser.
Second, on the factory AC system there is what appears to be a one way valve (please see attached picture.) What I can't figure out is that is would block flow if my first assumption is correct. What is this thing? What am I missing? Should I or can I leave it out with the new sanden/R134A setup. For those who have installed an aftermarket kit, did they come with one? I can't find much info on this. Anything y'all can add would be huge help!
Thanks!!
Thanks!!
I have factory ac on my 79 converted to 134a. I have replaced everything except hoses and evaporator at one point or another. My dryer is located after the condenser.
I have the same piece in the skinny hose exiting the dryer, I don't think it is a valve but more likely an adapter of some kind. I suppose it could be a check valve. The only valves I know of are the expansion valve located near evaporator and the service valves if you have them on the compressor.
Lights_Guy3
04-02-2016 02:43 PM
1968F250429
05-27-2010 12:19 AM
obtunaman
06-09-2006 06:46 AM
