Steering Wheel Play
Old Aug 22, 2021 | 06:41 AM
Colemater's Avatar
Colemater
Steering Wheel Play
I upgraded my sons steering box to a red head and his pump to a siginaw from wild horses 4x4 and the truck steered effortless and was tight for about six months
The steering is now very loose again (6” play)
power steering fluid is full, no breaks in belts, no obvious breaks in the linkage or sorbet steering components
any ideas on what happened?
Old Aug 22, 2021 | 06:46 AM
foofees's Avatar
foofees
Do you still have the rag joint in there? That would be my first check. If that seems fine, have your son turn the steering wheel while you watch the tires and or steering linkage for movement/play. It sounds like something came loose, just gotta find which part is the culprit.
Old Aug 22, 2021 | 07:30 AM
Colemater's Avatar
Colemater
thanks
rag joint looks good
pit it on jack stands and turned the wheels back and forth and everything looks good
thats why I’m stumped
i wonder if something happened in the box itself
Old Aug 22, 2021 | 07:52 AM
foofees's Avatar
foofees
If something happened inside the box, the steering wheel will turn and the tire will not. That could also be something loose in the linkage. Since you have it on jack stands, i'd give the tires a good tug and push, that will single out the linkage.
Old Aug 22, 2021 | 09:59 AM
Old Guy F-250's Avatar
Old Guy F-250
Just an idea, look it before the jack stands
Old Aug 22, 2021 | 02:49 PM
tbear853's Avatar
tbear853
It's a Dent I think, maybe it's blue and white, I'm guessing '73-'79 years. Maybe it's 4x4. If 4wd, it is either "inverted Y" (junk if on a '76 or '77 4wd ...just MHO) or "T type" steering ('78-'79 setup pittman arm, drag link, tie rods all ... is super on a '76 or '77).
Look closely at both ball joint ends of drag link for slightest play, check box mounting bolts too. On stands or not, with engine OFF and the keys in your pocket, parking brake set, in park if auto or first if manual ... have your son just rapidly rock the steering wheel left to right to left a few times while you are laying under the front feeling with your hand for play at joints, listen close too. He doesn't need to rock the steering wheel more than a couple or three inches, we are just looking for any detectable play here.
What I do is grasp the ball joint to include both parts connected with a clasping fashion at the same time in one hand thus wrapping my fingers tight around the joint ... but a finger bridging the two suspect parts works too, any play will be felt .. but one might get grease on the hand, palm ... or finger. Rubber gloves work here.
Also raise the hood and watch the rag joint, universal joint, any connections to shafts from steering collumn to steering box. I have a RedHead box, it's never acted loose.
Old Aug 22, 2021 | 03:47 PM
redroad's Avatar
redroad
I'm curious as to tire size and if there has been any lift or suspension and steering alterations to the truck other than the Redead power steering gear box (3 or 4 bolt ?) and the Saginaw power steering pump (what is the psi rating on pump ?).
Old Aug 22, 2021 | 05:38 PM
kegger66's Avatar
kegger66
WH Saginaw's are 1100 psi rated
Old Aug 22, 2021 | 08:45 PM
Christmas's Avatar
Christmas
Putting it on stands will not reveal any worn or loose parts. You need that stress of being on the ground.
Old Aug 22, 2021 | 09:11 PM
Colemater's Avatar
Colemater
Thanks all
some good ideas in here
Old Aug 28, 2021 | 01:51 PM
Colemater's Avatar
Colemater
so I spoke to red head technical support yesterday - my box is about 3 days from being out of warranty so good thing I called
they told me to drive the truck and see if it tracks straits - it does - in fact it tracks strait at 12 o’clock, 2 o’clock and 10 o’clock. What happens is when I go past 2 o’clock or 10 o’clock the truck sharply darts to the right or left (more pronounced on the right)
the technician told me most likely the steering shaft has slipped off of top dead center on the gears and is rolling over the gears as opposed to being in the center
i am supposed to call them back with the behavior of the truck on Monday, but I think they are going to tell me to make an adjustment on the box (based on what he said it sounds like the box adjustment screw is too tight, not too loose)
I’ll update this when I hear back next week
thanks for all the good advice
Old Aug 28, 2021 | 04:38 PM
F-250 restorer's Avatar
F-250 restorer
I would NOT put it up on jack stands. Free play is going to show when you have weight on the front wheels. I'd leave the engine off, and get under it with a flash light while someone is in it turning wheel from side to side. That will show you where the play is. Good luck.
Old Aug 28, 2021 | 07:55 PM
tbear853's Avatar
tbear853
Just trying to wrap my head around that one.
Old Aug 28, 2021 | 11:26 PM
John89's Avatar
John89
I just read and posted on another thread that might be an easy solution.
Check the steering wheel nut and the nut and lock washer on the pitman arm.
Take a gander at that other thread as well.
Hopefully it's not in your box.
351Cleveland C4
15
Jul 15, 2013 01:06 PM
LRMetric
Oct 24, 2012 11:41 AM
kwemj 67
Sep 2, 2010 10:26 PM
Mustangfreak
May 13, 2009 08:01 AM
ricalbuq
Dec 19, 2006 06:50 PM
