Steering Wheel Play
Old Dec 17, 2006 | 08:57 PM
ricalbuq's Avatar
ricalbuq
Steering Wheel Play
I purchased a 1988 F150 SC xlt/lariat 4x4, 302, in running condition for 1000.00. I was please with the purchase price and have put a quick 700.00 in it for steering, ball joints, frame weld, and something else, anyway there is some play in the steering wheel. What can I do to tighten the steering so there is not so much play in the steering wheel???
ricalbuq
Old Dec 17, 2006 | 09:04 PM
wrenchturner's Avatar
wrenchturner
I'd have someone in the cab turning back and forth on the wheel till you see movement in the tires. look at all the steering components until you find where the slop is. The steering box is adjustable and is easy. But check the joints in the steering colum, and the links in the steering under the truck. let us know what's loose.
Jason
Old Dec 17, 2006 | 09:24 PM
RMS94's Avatar
RMS94
Here is a website w/ the procedure to tighten the steering box;
http://autorepair.about.com/library/a/1h/bl136h.htm
Just becareful and check the slop every quarter turn as stated in the procedure. If the gearing mesh is too tighten the steering effort and control will be effected.
On my 1994 it took 1-1/4 turns to eliminate the slop.
Roger
Old Dec 18, 2006 | 07:06 PM
ricalbuq's Avatar
ricalbuq
thanks for the quick reply. I plan on doing this procedure on Friday so I will post with the results of the procedure. thanks again,
Randy
Old Dec 18, 2006 | 07:08 PM
ricalbuq's Avatar
ricalbuq
Will tightening the nut holding the steering wheel make any difference? I have not done this but was just wondering??
Randy
Old Dec 19, 2006 | 12:40 AM
desertdave55's Avatar
desertdave55
Randy
A loose nut behind the wheel will always cause problems.
Sorry, just had to say it! The steering wheel fits onto the splined steering shaft quite securely. If that nut had become loose and the steering wheel had worked itself up out of that spline, you'd immediately know it was loose right there!
Do as wrenchturner suggested to determine exactly where the play is. Could be the steering box, could be the knuckle on the steering wheel shaft, could be something else.....
Old Dec 19, 2006 | 05:00 PM
ricalbuq's Avatar
ricalbuq
Thanks will check the slop first and go from there. You guys are helpful.
Randy
Old Dec 19, 2006 | 06:50 PM
SilverSport's Avatar
SilverSport
Could also be on the steering shaft ... that's where mine is ... may be in the box too, but I am gonna shim between the shafts first .... it is a two peice shaft from the column to the box under the hood.
ricalbuq
Mar 16, 2007 02:44 PM
ricalbuq
Feb 3, 2007 07:21 PM
ricalbuq
Texas Chapter
Jan 6, 2007 12:04 AM
ricalbuq
Dec 20, 2006 10:52 AM
ricalbuq
Dec 19, 2006 04:58 PM
