It takes several seconds for the transmission to engage when shifting to drive. Is this the trans failing or maybe torque converter. Once in gear it drives well.
It could be a clogged trans filter, but if it’s that bad it means you need a rebuilt trans. There are posts here about the “feed” bolts coming loose, I think you have to drop the pan and valvebody to get to them. Be careful doing that.
I'm having problems with my torque converter I believe is giving me the 628 code also 634-452 which is a speed sensor I just replaced that but my trip my speed out of my speedometer bounces up and down now. I can take off at first and second no problem I can back up no problem but most time I try to take off in 3rd and drive and won't go until I'm already rolling in second or first is it my torque converter I need to know anybody help please
[QUOTE=Ausimc;20689394]I'm having problems with my torque converter I believe is giving me the 628 code also 634-452 which is a speed sensor I just replaced that but my trip my speed out of my speedometer bounces up and down now. I can take off at first and second no problem I can back up no problem but most time I try to take off in 3rd and drive and won't go until I'm already rolling in second or first is it my torque converter I need to know anybody help please
I would recommend starting your own thread to avoid any confusion between your specific issues and the OP. Plus a little detail on what vehicle your trying to diagnose may be helpful also. Put as much detail as you can about what the problems are and what test's you may have already done helps a bunch too. Remember we're not there so the only things we know are the things you tell us.
