Sponsored by: Auxito
trans problem
Old Nov 14, 2010 | 03:17 PM
xxl_2321's Avatar
xxl_2321
trans problem
i was driving down the road slowed down to get over then when i got on it to speed back up it had no power. well got it home and it acts like it is stuck in 3rd or 4th and wont come out. the overdrive light is flashing any ideas on what the problem is?
Old Nov 14, 2010 | 03:36 PM
n5926g's Avatar
n5926g
More information would be helpful....V-8,V-6,miles on the clock etc.My guess would be Torque converter stuck in O/D mode.Perhaps a stuck solenoid,or something to that effect.usually however when this happens,the Torque converter wont disengage from O/D and it will stall the engine when coming to a stop.
What color is the tranny fluid,and does it smell "burnt"?
Old Nov 14, 2010 | 04:56 PM
xxl_2321's Avatar
xxl_2321
it is an 02 f150 5.4 4x4 with the 4r70w that has 150000 miles. fluid is good. it will idle for a little while when it is in gear and then it will die.
Old Nov 14, 2010 | 05:24 PM
FordMstrTech's Avatar
FordMstrTech
On a 4r70w the default gear is third gear. Beins the O/D light is flashin u will have a code. My guess is something has failed ans it is defaulted to third gear so u can limp it home. Possibly shift solenoids, speed sensors, etc. More than likely an electrical issue.
If the torque converter is locked up and will not unlock, the engine should die when u r coming to a stop...
Old Nov 15, 2010 | 03:06 PM
xxl_2321's Avatar
xxl_2321
it was fuse 23 under the hood o2 wire shorted out
Old Nov 15, 2010 | 06:29 PM
FordMstrTech
Thats great perty cheap fix....
Be sure u clear your codes!!!
Tanner2255
Aug 4, 2012 10:11 PM
Pablo-UA
Aerostar
Dec 3, 2008 08:19 AM
ekennede
1983 - 2012 Ranger & B-Series
Aug 25, 2008 07:26 PM
handsomerob
16
Sep 24, 2007 06:05 PM
Marc150
Jan 19, 2005 12:33 PM
