Speedometer Cable
Old Aug 26, 2021 | 06:44 PM
motogotor's Avatar
motogotor
There is a speedo gear in the transmission that comes out easily once you remove the cable adapter. I downloaded a GPS speed check app and surprisingly my speedo is pretty accurate. It's dead on up to about 50mph and then starts to read a little slow. 65 on the speedo is 68, 70 is 74/75. I'm not sure I can expect it to be much more accurate than that. I can only assume that the PO changed the gear when he put the 31" tires on the truck.
On another note, I'm leaking transmission fluid at the speedometer cable adapter. I took it out of the case and it looked like it had a slot for an o-ring but there wasn't an o-ring on it. There also isn't any seal between the driven gear and the adapter. I fished an O-ring out of a bucket of O-rings I have and put one on the adapter and took it for a drive but it's still leaking. I've looked all over the Internet and it looks like the housing and adapter I have is rare so I haven't been able to find the parts I need or even any information as to whether or not there should be a seal of some sort on the gear itself. I was thinking I might have to stop by an transmission shop and see if anyone there can tell me what I need to seal that up but if anyone on here knows, I'd appreciate any info you have.
Old Aug 28, 2021 | 06:44 PM
JEFFFAFA's Avatar
JEFFFAFA
Sure. Remove the speedo cable out of the trans or transfer case if it's a 4X4. On the cable's end you will see the gear I referenced. It is held in place by a "C" shaped metal clip. Remove the clip and the gear will slide right off.
And OP, there should be an o-ring on the adaptor but not the gear. If still leaking, you might have installed an o-ring that is too thin walled.
Old Aug 28, 2021 | 07:27 PM
Pcmdub's Avatar
Pcmdub
Yeah. That is what I thought too but that is the other type of cable. The cable referenced in this thread does not have a gear at the end. Apparently it is in the housing of the adapter on the tail shaft.
Old Aug 30, 2021 | 02:42 PM
motogotor's Avatar
motogotor
My bad, I should have included a pic in the original post. Here is my speedo gear adapter. There is a metal gear in the trans but it's a metal to metal joint between the gear shaft and the cable adapter so nothing there to stop a leak. Seems like there should be something there?
diggerrigger
Jun 3, 2024 02:02 PM
Sparty73
Nov 20, 2019 09:07 PM
trokita101
Nov 3, 2014 08:29 PM
hemiyota
May 6, 2006 06:56 AM
Nathan
Apr 30, 2001 03:40 PM
