Sponsored by: Real Truck
Rear diff
Old Aug 11, 2021 | 03:36 AM
RonC80's Avatar
RonC80
Rear diff
So what does everyone use for the rear differential fluid? I have a leaking cover so I am replacing it and new gasket. Does Ford use synthetic from the factory? If they don't and I would like to put synthetic in it . What adverse effects happens if I don't get all the old out?
. 08 f250 super duty 5.4 4x4.
What weight would you all recommend? I live in upstate New York. Not any off road use except maybe hay field to pick up a deer that I don't feel like dragging..
. Again I'd like to thank everyone with the help with fuel pump issue.
Old Aug 11, 2021 | 07:04 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Ford uses full synthetic from the factory and has for a long time. There is no replaceable gasket it's a bead of silicone.
Denny
Old Aug 11, 2021 | 07:09 AM
jav_eee's Avatar
jav_eee
Denny
There sure is a gasket: Lube Locker
Old Aug 11, 2021 | 07:10 AM
senix's Avatar
senix
I use the Valvoline with friction modifier. No gasket as Denny indicated.
Old Aug 11, 2021 | 08:07 AM
rvpuller's Avatar
rvpuller
What silicone are you using on the cover, my DRW is getting close to a change and on my last DRW I had a problem getting something that worked.
Denny
Old Aug 11, 2021 | 08:12 AM
senix's Avatar
senix
Denny,
Will have to look a bit later as I am getting ready for a meeting
Scott
Old Aug 11, 2021 | 08:14 AM
nydiver's Avatar
nydiver
RTV for oil contact for sure. We've used $3 tubes of 100% GE Silicone caulk for years on gear cases...
Old Aug 11, 2021 | 09:52 AM
speakerfritz's Avatar
speakerfritz
Denny
depending on your diff model....there are replaceable gaskets out there....but...I recently did front and back diff fluid and used a replaceable gasket on the front and since I could not find a m300-14 gasket, went with the diff sealer. The front replaceable gasket has a very slow droplet accumulationthe rear done with the sealer is not leaking, seeping, weeping, at all.
when you use the sealer you fit everything into place finger tight...wait 30 minutes to an hour depending on the sealant.....then you tighten to correct spec.
Old Aug 11, 2021 | 03:10 PM
CP Dubbs's Avatar
CP Dubbs
LubeLocker gasket for the win.
75w140 for the rear diff.
Schaeffer or Amsoil Severe Gear is my preferred go to.
Valvoline is certainly an option,and is cheap compared to "boutique" lubes.
You could put on the factory optional aluminum cover if your steelie is getting thin from rust.
Old Aug 11, 2021 | 04:41 PM
DoOver's Avatar
DoOver
Do you have a part number?
Old Aug 12, 2021 | 05:14 AM
CollinsCD's Avatar
CollinsCD
I used Valvoline 75W140 full synthetic fluid that contains the limited slip additive with the LubeLocker gasket on my rear. No need to deal with the silicone mess and wait for it to cure before adding your fluid. Plus the LubLocker gasket is reusable too!
Old Aug 12, 2021 | 05:16 AM
CollinsCD's Avatar
CollinsCD
Part number for the 10.5 Sterling rear is LLR-F105.
Old Aug 12, 2021 | 06:16 AM
Akley88's Avatar
Akley88
i switched to lucas synthetic 75-140 when i did my gear swap. i also have a banks rear diff cover which has a built in gasket.
Old Aug 14, 2021 | 06:55 AM
Bugzilla46310's Avatar
Bugzilla46310
I went with Lucas oil full synthetic, lube locker gasket and an aftermarket cover identical to the Ford ribbed cover and stainless hardware.
Old Aug 17, 2021 | 09:47 PM
Overkill2's Avatar
Overkill2
Yep, I use a Lube Locker in my Sterling 10.5.
Here's the oil I went with when I changed it out:
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
The next time I change it, I'm going with this:
https://smile.amazon.com/Triax-Syner...ci_mcx_mr_hp_d
I did a thread here when I serviced my rear end.
https://www.ford-trucks.com/forums/1...ng-10-5-a.html
pete500
15
May 19, 2020 10:31 AM
bballcrf
23
Oct 15, 2014 02:09 PM
cjspack
Apr 2, 2009 09:41 AM
deano2
Nov 15, 2005 09:43 AM
2000F150Gal
Oil & Lubrication
28
Jun 11, 2004 08:46 PM
