Long crank start even when cold
Old Aug 3, 2021 | 09:19 PM
SmackDaddy's Avatar
SmackDaddy
You will need a lot more pressure than shop air to truly air test a HPO system. Some of these shops like DieselSite use hydraulic testers that put out a few thousand psi because that’s what the HPOP output is under hard acceleration. 150psi shop air will find a gross leak but the smaller leaks not so much.
Old Aug 3, 2021 | 09:25 PM
bismic's Avatar
bismic
I would suggest getting it out on the highway and do those accelerations mentioned above. At least 20 minutes of running it fairly hard.
Old Aug 4, 2021 | 08:59 AM
53jimc's Avatar
53jimc
Agree, it takes a while to get all of the air out. After doing all the work on the '05, I would take it on about a 30 mile drive. I'd drive it through the countryside fairly slow, stop and check codes a couple of times, then a 15 mile jaunt on the interstate at 70 mph (maybe a bit more), come back home, check codes, let it idle cool, shut it down then try to restart.
Several times I'd get a P2552 (I think that's the code) that would not reset. I had to unplug the scanner, turn on headlights, disconnect batteries and reconnect everything to get that one to clear.
Good luck.
6.0dieself350
Aug 29, 2020 07:59 PM
bubblechaser
Nov 13, 2013 09:16 AM
Donzi Dude
Aug 6, 2013 06:08 PM
Peterbilt376x
20
Jun 21, 2011 08:44 PM
