Booster reading
trying to diagnose an issue w brake booster on a 65 f350 dually firewall mount.High and stiff pedal. My vacuum reading to booster including check valve is 22 which seems ok. Just wanted to confirm that reading. Thanks in advance
Dennis
One test for this used to be, shut the engine off, and watch the brake pedal carefully when restarting. There should be a little twitch downward. I think, it's been a long time.
If you have to apply a very high amount of pressure to stop, more that likely you will need to replace your booster.
Don't overlook anything like blockages in the hose or the hose collapsing on the inside.
You can disassemble them with a brake booster spanner. The blue one is 36" long. In this case the two halves capture the outer edge of the diaphragm which makes the seal separating front from back. The check valve is there to try to preserve the vacuum on the front half when the engine stops otherwise it should be open to allow the vacuum the enter the chamber. That places a draw on the diaphragm at all times when running and only when you apply foot pressure to the pedal does open the rear intake to override the internal spring pressure holding the diaphragm back. A foam filter allows replacement air to be drawn from the cab where the push rod enters the rear half to allow the diaphragm to move forward on demand. Not a lot that can go wrong. Depending on where you draw vacuum from the check valve can get sticky from oils being drawn in if you have some blowby. The diaphragm can tear due to age. The foam filters deteriorate - I've been using surgical grade foam to cut new filters by hand and it will hold up for a lot longer than the original stuff. Are you still using the original single chamber master cylinder or has it been swapped to a dual chamber master?
OP Dennis, and Doc Charles. To test booster, turn off engine, pump pedal several times to exhaust all reserve vacuum, put your foot on the brake pedal and start the truck. The pedal should fall away slightly when the motor starts and pulls a vacuum. If it doesn't you have a defective booster, or no vacuum to the booster. period.
Kent-Moore J-9504 Brake Booster Spanner 1962-68 | eBay
Kent Moore J-9504 Vacuum Brake Booster Spanner Wrench Tool | eBay
so check this out… I found out that after I hooked the vacuum line back to the booster after adjusting the idle/air, it ran crappier. So my brother gave me a pro tip. I sprayed starter fluid around anywhere there could be a leak in the booster and noticed a change in the engine idle. Hence the booster is leaking. The o ring where master cylinder attaches was a little rough as well as where it seats to that rubber part of the diaphragm on the outer side. Taking on getting that sealed up tomorrow . Diaphragm felt ok and dry of brake fluid so that was good at least.
