Brake Vac Booster??
Old Sep 22, 2003 | 11:47 PM
lotty1525's Avatar
lotty1525
Brake Vac Booster??
My brake pedal will not sponge back up once I apply the brake. It will move back slowly sometimes, but only with excessive pressure applied. I Do not know if it is the vacum booster because when the vacum line is not connected to the booster from the intake it will spring back up. Any suggestions on what this may be and how i can fix this problem??
Old Sep 23, 2003 | 01:36 AM
NorthernCanadian's Avatar
NorthernCanadian
Brake Vac Booster??
It could be your Vac booster, the rubber diaphragm might have a hole in it and the vacuum is backing into the firewall side making the pedal not come back as it should. Has your overall braking ability deteriorated?
Old Sep 23, 2003 | 09:39 AM
armyguy's Avatar
armyguy
Brake Vac Booster??
Lotty you have a bad check valve in the booster, I know it`s not what you want to hear, you can`t get just the check valve either,you need a new booster..the check valve keeps vacuum from passing through the line when the brake is not applied,if it leaks a bit it`ll apply just enough vacuum to make your pedal stay down, i tried fixing one with a return spring but the booster just got worse, finally it developed a leak and every time I hit the brake the engine had a vacuum leak,save yourself a headache and get a booster..
