ABS light
Old Jul 14, 2021 | 03:22 PM
Desertdeputy's Avatar
Desertdeputy
5th Gear
ABS light
Changed the brake pads and rotors on my 02 F350 4x4 and the ABS light activated and I can not get it to stay off. Any suggestions?
Old Jul 14, 2021 | 03:29 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Did you plug the hub sensors back in?
Did you damage the hub sensors when you were reinstalling a rotor?
Do you have an OBDII scan tool so you can see which code the ABS module is setting?
Below are a few taken from the Ford Service Manual section 206-09.
Old Jul 15, 2021 | 02:33 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
What the Souster said, getting the code will help narrow the diagnosis.
Did you flush the brake fluid when doing the brakes?
Old Jul 15, 2021 | 09:48 AM
Desertdeputy
5th Gear
I did not flush the brake fluid but had to replace some of the fluid that spilled out of the reservoir when I compressed the calipers. I’m working on getting a code reader. The one I have does not identify the problem with ABS
Old Jul 16, 2021 | 02:08 AM
aawlberninf350
It's a Van Gogh
If the brake fluid level looks good, maybe a severe brake event or 2 might fix it. Activate the ABS. Best if you don't kill anybody in the process.
Old Jul 16, 2021 | 08:31 AM
uglypitbull's Avatar
uglypitbull
I had a weird incident...my ABS light came on after doing some engine work. Pedal was bouncy like something was pushing back and ABS light told me something was up.... figured I would deal with it next day I had off. I noticed my vacuum caps were rotten where the hubs got their locking pressure, so I capped them as a maintenance thing. Went to start truck to pull code and no code.....brakes were normal. I didnt touch anything brake related while working.
Not sure if that's what the issue was or how that would affect brakes, but it was the damndest thing.
Old Jul 16, 2021 | 05:39 PM
MoBill122's Avatar
MoBill122
Papa Smurf
Make sure you didn't leave the plug behind fender guard unplugged...or maybe you broke a wire
Brenda Lamka
28
Apr 6, 2014 10:39 PM
1bad67sbf
2004 - 2008 F150
Nov 25, 2010 01:25 AM
Ohio Ford Farm
1983 - 2012 Ranger & B-Series
Sep 20, 2009 08:30 PM
buffalobob
May 9, 2007 10:21 PM
B-DOGG
Jul 20, 2005 01:51 PM
