Help please
Old Jul 16, 2021 | 01:19 PM
JMFWOOTEN's Avatar
JMFWOOTEN
Help please
I have a 2002 7.3 an doing a motor swap from a 99 to my 2002 body with the 99 7.3 . Plus changing out wiring harness , glow plugs , glow plug Cylinoids , pigtail , an valve cover gaskets . On the 99 are there any special requirements I need to do or buy before I make swap . Does this match up in the 2002 body an tranny ? Any info will help please
Old Jul 16, 2021 | 01:48 PM
Walleye Hunter's Avatar
Walleye Hunter
That would depend on if the engine is an E99 or a 99.5. Transmission and body pretty much no problem, the issues come into play with the turbo intake tube and downpipe alignment. If it's a 99.5 it's plug and play except maybe for an intake air heater, which is not hard to work out.
Old Jul 16, 2021 | 02:01 PM
udsuth78's Avatar
udsuth78
What engine was in the 02 originally? Do you have the complete wiring harness including pcm? Does the pcm match the transmission in the 02?
Old Jul 16, 2021 | 02:07 PM
JMFWOOTEN's Avatar
JMFWOOTEN
Yes
yes I have the complete wiring harness an cpm it’s the 7.3 international 8 digit is f , as far as checking the pcm I was taking the wiring harness out the 99 cpm an all an relacing it into the 02
Old Jul 16, 2021 | 02:10 PM
JMFWOOTEN's Avatar
JMFWOOTEN
not sure truck was for sale it was hit by deer an motor an tranny was solid . Only right fender an hood damaged . I paid 2000 for whole truck which I know it’s way worth more than that it only has 140,000 original miles on motor. I’ll call an see real fast it’s at the shop
Old Jul 16, 2021 | 02:12 PM
udsuth78's Avatar
udsuth78
Should be fine as long as the transmissions match. Can't run an automatic off of a PCM from a standard and vice versa
Old Jul 16, 2021 | 02:13 PM
JMFWOOTEN's Avatar
JMFWOOTEN
it is a auto an other truck the 99 is a auto
Old Jul 16, 2021 | 02:21 PM
Bonanza35's Avatar
Bonanza35
Should go right in. You can look at your spider and see if they are the same. Also the glow plug relay to see if they are the same. Other then that direct fit. Having the harness really helps, go for it. If it's and early motor it won't have the intake heater.
Old Jul 17, 2021 | 01:30 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
What Chet said. A pic of the top of each engine should tell the tale.
b-wolff
Apr 5, 2017 05:59 PM
panningbros
Mar 11, 2011 02:13 PM
NAMDROF
Mar 2, 2011 09:05 PM
mikes70gto
May 27, 2010 02:47 AM
skoto1
General Diesel Discussion
20
Feb 6, 2008 06:42 PM
