Temp Sensor Wiring
Old Jul 5, 2021 | 12:20 PM
xenophone's Avatar
xenophone
Temp Sensor Wiring
I need help hooking up my temperature sensor. The temp gauge has not worked since I've had the truck (1984 F-150 i6). I converted the ignition back to Duraspark II. When I did so I tore out the computer.
If you look at the pictures below, there are two wires coming off the sensor, one green and one black.
I have three unused wires coming out of the instrument panel/dash.
Chiltons says the sensor connects to a red/white wire. But the sensor has two wires. Is the black one for ground? I tried running the black wire to ground, and hooking up the green wire to each of the three unused wires from the instrument panel, and none of them worked.
Old Jul 5, 2021 | 01:58 PM
Max Capacity's Avatar
Max Capacity
FWIW, My 86 has one black with white strip and one green with yellow strip.
The new connector I got from NAPA a few years back had the same color coding. I just went out a took these pictures.
Old Jul 5, 2021 | 02:08 PM
Rembrant's Avatar
Rembrant
That temp sensor should only have been for the computer. The temp sensor for the temperature gauge is at the back of the engine block on the passenger side and has only one wire. The wire is in the DSII harness and feeds around the back of the engine from the driver's side. Even in the EFI trucks, the EFI computer is wired independently of the instrument cluster.
Old Jul 5, 2021 | 02:29 PM
Max Capacity
Oh yeah, ^ I see, now that you mention that, I recall there's another temp sensor with a single red wire from on my v8.
Old Jul 5, 2021 | 02:50 PM
Rembrant's Avatar
Rembrant
Ya, there's one for the computer (if equipped) and another one for the temperature gauge with only one wire.
Old Jul 5, 2021 | 04:52 PM
Franklin2's Avatar
Franklin2
The others are correct, that is not the right sensor. As you were pulling the computer and it's wires out, that sensor would have been in the computer harness, and you would have known that it's not used anymore. You may have been in the matthew thread debacle and that point may have been lost. Sorry if that happened to you.
Old Jul 5, 2021 | 06:17 PM
xenophone's Avatar
xenophone
Haha no problem. I probably just forgot.
Old Jul 5, 2021 | 06:18 PM
xenophone's Avatar
xenophone
Okay found the temp sensor and got it working. Thanks for the help.
What does the computer do with the other temp sensor?
Old Jul 5, 2021 | 06:20 PM
ctubutis's Avatar
ctubutis
This.
There is a difference between a sensor and a sender; the green/black is the 2-wire setup for the EEC-IV computer (it makes adjustments to the air/fuel ration based partially on that sensor). The red/white or white/red (I forget which) is for the water temp gauge, the other is for the oil pressure.
Old Jul 5, 2021 | 07:02 PM
Franklin2's Avatar
Franklin2
Like was mentioned in the previous post, whether the engine is cold, warm or hot, makes a big difference in making the engine run correctly and for emissions strategy. The old style engines with no computer had temperature sensing vacuum switches to turn things on and off with vacuum depending on the engine temp. EGR was one of them. Your old style carb now controls the idle speed when the engine is cold, making it idle faster. The computer carb had a little bit of control on the fastest step, but all the other fast idle settings were controlled by a idle control motor mounted on your old carb, depending on engine temp and a few other parameters. This was controlled by the computer, and it got it's engine temperature info from that sensor.
It worked basically like fuel injection on a primitive scale.
Mbizzal
Apr 24, 2020 08:49 PM
FourXFord2
1978 - 1996 Big Bronco
Nov 21, 2018 06:38 PM
justshootme84
Apr 28, 2010 12:36 AM
branden.w
Nov 21, 2009 07:09 PM
redlightning93
Feb 3, 2009 12:11 PM
