1978 - 1996 Big Bronco
HEGO problems
Old Nov 8, 2018 | 07:24 PM
FourXFord2's Avatar
FourXFord2
HEGO problems
Hey everyone, been awhile since my last visit. Been struggling to get rid of my hego not switching code. I replaced it last week, but am not entirely sure that the plug is pinned correctly. The sensor has 4 wires, black, grey, and 2 white. the vehicle side is blk, ground, grey/yellow, hot in run, grey/lt. blue, pin 29 at ECM, orange to pin49 at ECM. I'm not sure how to check the sensor to figure which wire goes to what. I have even tied finding another truck to compare it to, no luck yet.
Old Nov 15, 2018 | 02:18 PM
Redark1's Avatar
Redark1
DOES THIS HELP
Old Nov 15, 2018 | 09:20 PM
FourXFord2's Avatar
FourXFord2
Originally Posted by Redark1
DOES THIS HELP
That's one half of the problem. I am going to chase the orange and gray/yellow back to EEC, make sure I have continuity. How would I check the sensor side of the plug, it could be they give me the wrong sensor.
Old Nov 21, 2018 | 02:18 PM
Kemicalburns's Avatar
Kemicalburns
are you running an efi setup that needs this type of o2 sensor? because our stock SD would use a different o2.
Old Nov 21, 2018 | 06:38 PM
FourXFord2's Avatar
FourXFord2
I'm using the factory type EFI standard issue 1991. I haven't had time yet but I want to check the orange wire to make sure it has continuity all the way to the EEC. Yesterday my speedometer gear stripped in the cold weather so now getting a code for no VSS signal now as well.
japrine
Apr 22, 2015 12:50 PM
76f250highboys
May 20, 2010 12:23 PM
JohnInBHM
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Aug 13, 2007 11:26 AM
Dave-A
Aug 6, 2007 07:58 AM
irishguyincc
1983 - 2012 Ranger & B-Series
19
Nov 12, 2005 08:56 AM
