Can someone identify this part/sensor?
Old Feb 2, 2009 | 07:08 PM
redlightning93's Avatar
redlightning93
Need help with identifying this part/sensor that was broken off by the PO. It screws into the lower intake on my '85 F150 302FI. You can see the large white plug that plugged into it. There is another one just forward of it that you can barely see in the pic. What is its purpose and is it needed?
Old Feb 2, 2009 | 10:13 PM
dan76's Avatar
dan76
Get a Haynes manual and use the wiring chart to ID the sensor by wire color. If I had mine readily available, I'd look it up for you.
Old Feb 2, 2009 | 11:46 PM
gofastl's Avatar
gofastl
Is that the air charge tempreture sensor?
Old Feb 3, 2009 | 12:01 AM
Sycostang67's Avatar
Sycostang67
The ACT sensor should have a yellow/red and blk/wht wire. I think that is the Engine temp switch, which should have a Lt. green/yellow and black/white wire. That wire looks dark green though, and the only things I see right away with a dark green wire are the TPS and MAP sensors. They have 3 wires though, not 2.
Old Feb 3, 2009 | 09:10 AM
bfbiker's Avatar
bfbiker
part
how about a aint knock sensor?
Old Feb 3, 2009 | 12:11 PM
redlightning93
Gofast you just may be on to the problem. From reading on Google it reads the temp of the incoming air and the computer adjusts the fuel mixture accordingly. Thanks for the input.
AutoZone.com | Shopping | Parts | Product Detail - Air Charge Sensor
