Sponsored by: Real Truck
2007 SD 6.0L - MAP sensor circuit ?s
Old Apr 27, 2010 | 12:52 AM
justshootme84's Avatar
justshootme84
I've been searching for days trying to find the wiring diagram or color codes for the 3-wire plug to the M.A.P. sensor. I believe the middle wire which is Lt green/ Black is the signal wire to the PCM, while the White/ Brown wire is 5.0v constant. Not sure where the grey/ red wire goes to. JSM84
Old Apr 27, 2010 | 08:48 AM
tex25025's Avatar
tex25025
This what you need?
EDIT: Hell, I thought it would be bigger then that. I'll see if I can change that.
Old Apr 27, 2010 | 08:59 AM
tex25025's Avatar
tex25025
Best that I can do, sorry.
Old Apr 27, 2010 | 10:34 AM
cartmanea's Avatar
cartmanea
Along with the +5v and output signal voltage, there has to be a ground.
Old Apr 27, 2010 | 10:39 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Old Apr 28, 2010 | 12:36 AM
justshootme84
Thanks for the diagrams, too bad they don't show the color for each wire. Had a local mechanic hook up a Multitester voltage meter to each of the 3 wires, which is how we found the 5.0v constant power. But the othe rtwo wires don't show any difference betwen them when changing the engine RPM, with a voltage reading of about 0.48v. I did find a better wiring siagram in the Tech Articles, but even that does not show wire colors.
84StraightSix
Aug 31, 2014 12:35 PM
steveamann
17
May 20, 2013 07:34 PM
master link
Aug 16, 2006 09:46 PM
mauicruza
1966 - 1977 Early Broncos
Mar 15, 2005 02:18 PM
mike L
Oct 4, 2004 07:44 PM
