Sponsored by: Kumho
Power Steering Help
Old Jul 5, 2021 | 12:19 PM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Power Steering Help
I usually hang out in the older Truck Forum but have a question I'm hoping someone here might be able to help me with.
History: I have a 1956 F-100, with a 292 (not stock), C4 automatic Trans (also not stock) with a 9" with 350 gears (again not stock)
I previously installed a Toyota power steering box and a Saginaw power steering pump.
This winter I installed a Vintage Air combination HVAC system. In doing so the belt drives changed places and I can no longer mount my power steering pump in its normal location. It shares the drive belt with the water pump and with the new A/C & alternator bracket the power steering pump belt only contacts the water pump pulley approximately 2" not providing enough contact to safely provide water circulation within the engine.
I read several individuals have converted to electric power steering pumps and decided this might be a viable option for me. The Volvo S40 pump nestles under the cab floor with no interference problems via a 1/4" home made bracket.
Whew! Now to my question.
The Volvo (has Ford motor company clearly embossed in it) calls for CHF11 or CHF202 fluid, the Toyota specs Mercon/Dexron. Soo what should I use? I really don't want to damage either the pump or the steering gear. I'm leaning toward CHF202. Anyone with experience got any suggestions?
Old Jul 5, 2021 | 03:30 PM
mark a.'s Avatar
mark a.
I wouldn't use the CHF fluid because it's a synthetic. Mercon Dexron would be ok but I would just put regular power steering fluid in it.
Old Jul 5, 2021 | 06:36 PM
bjmayberry2
Do you think it'll hurt the pump? I couldn't find any info on what would happen if I used ATF in it.
I read on a Toyota site not to use power steering fluid in their system. Something about seal problems.
Old Jul 6, 2021 | 02:45 PM
mark a.'s Avatar
mark a.
Nothing wrong with using ATF I just wouldn't use CHF.
FordRun
Mar 6, 2013 09:48 PM
hhcobra
Oct 2, 2011 10:22 PM
ROCKY1956
Apr 29, 2006 06:40 PM
celticrebel
1978 - 1996 Big Bronco
Oct 22, 2003 12:40 AM
galu
Apr 6, 2001 04:26 PM
