power steering pump
Old Mar 5, 2013 | 06:55 PM
FordRun's Avatar
FordRun
power steering pump
my power steering pump going out on my 74 f100
i had auto parts order me one.
my question is what do i need to know about taking it off and putting it back on..
i just learn i need a puller to take off the pulley..
i hope i can take the power steering pump to a shop have them take it off
and put new 1 on it
then i can hook it back up to truck
i heard you have bleed power steering pump ?
Old Mar 5, 2013 | 07:02 PM
fmc400's Avatar
fmc400
MSEE
You do need the puller. Make sure when you put the new pulley on that you put it on in the correct direction; if you put it on backwards it will never come off.
Old Mar 6, 2013 | 06:29 PM
FordRun's Avatar
FordRun
it does have a hum. i had added power steering fluid it was real low not sure if
its the pump leaking or the hose leaking
when i had added fluid it felt like the steering wheel didn't wont to turn
maybe air ?
should i just try to replace hose first ?
and howto bleed it ?
Old Mar 6, 2013 | 07:02 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
maybe air ?
Should use Type F for the power steering. The old Thompson pumps do not play nice with universal power steering fluid.
Josh
Old Mar 6, 2013 | 07:10 PM
JWC 3's Avatar
JWC 3
It will come off ! I have removed a couple that were put on backwards . With a torch !!!
Old Mar 6, 2013 | 07:29 PM
7636074460's Avatar
7636074460
keep in mind that the bracketry for the pump is behind the pulley also, so remember to get that on before installing the pulley onto the new pump. you can rent a pulley puller kit for a small deposit or buy one either way for roughly $30. as long as you have some sort of workbench and maybe a strong friend to help you, shouldnt have any problem doin that yourself. just take a silver sharpie and mark the front of the pulley with a big F or something before removable to avoid this backwards installation issue.
hoses can collapse on the inside so i recommend changing those, too. maybe even before you waste money on a new pump. theres a few different part numbers for the pressure hose so make sure it matches up to your old one. the return line can be replaced with bulk hose(parts stores should carry actual power steering hose.) another alternative you could use is either some better quality fuel hose or transmission cooler hose.
as far as bleeding. fill it to proper level and run the engine. make sure it stays full(to the low mark on the dipstick) air bubbles may/should occur and probably have to add more fluid a couple times.
after this, work the steering wheel all the way to the right, check and add fluid if needed. then work the steering fully to the left, check/add again. repeat this several times and it should be bled fairly well. at this point the fluid level can be more to the middle fill line, you dont want it completly full or overfilled while cold, i believe the dipstick even says "CHECK HOT" . it not going to be HOT until a drive around town. you have to allow room for the fluid to expand so keep it at the cold level until you know its warmed up well.
Old Mar 6, 2013 | 09:48 PM
FordRun's Avatar
FordRun
thank you for the info
RyAnIs1
May 17, 2009 05:39 PM
dennis299
Jul 19, 2008 09:54 AM
aj5601
1978 - 1996 Big Bronco
Sep 18, 2002 12:05 PM
hkmp5sd
Jun 15, 2002 12:13 PM
