coolant leak
Old Jun 9, 2021 | 09:58 AM
olddiesel's Avatar
olddiesel
5th Gear
coolant leak
I just bought this truck about a month ago. No problems everything runs perfect about 134 thousand miles when bought. Recently its been having some issues it would lose all power randomly and shut off it will take a second to turn over with a little throttle. i got under to check for any leaks see if maybe it was the radiator or something of the sort found a large coolant leak coming from the assembly under the water pump I'm not sure what it is again very new to diesels. looking for some help to see what this problem is the truck is a 1992 f250 7.3
Old Jun 9, 2021 | 01:01 PM
genscripter's Avatar
genscripter
Your waterpump seal probably went out. Replacing a WP is not that hard to do, just a pain to swap over the fan clutch first (reverse threads on that, LEFTY-TIGHTY, RIGHTY-LOOSE, and you have to rent a clutch puller from a parts store)
Here's a video explaining why you need to permatex some of the bolts on your WP: https://www.nickpisca.com/diesel/eng...idi-waterpump/
Also, remember the location of each water pump bolt, because they are different lengths for different reasons. Use RTV for the gasket AND the aforementioned bolts.
Old Jun 9, 2021 | 01:02 PM
genscripter
Just to help us diagnose this, could you post some pictures of the leak? It could also be a different leak than your WP, but who knows until we see some photos
Whitey5.0
May 30, 2021 04:11 PM
Greenlawnracing
Oct 16, 2015 10:06 AM
drbigknuckles
Jan 28, 2009 04:05 AM
98FordTruck
Jan 15, 2009 06:31 PM
leitrum
Dec 2, 2006 11:50 AM
