Sponsored by: Real Truck
Coolant leak
Old Oct 12, 2015 | 04:19 PM
Greenlawnracing's Avatar
Greenlawnracing
Coolant leak
Woke up today and found a large puddle of coolant under my truck - about two feet in diameter. Not very deep, but still present.
Started it up and had a look - I can see it on the lower radiator hose.
How do I chase it down?
Old Oct 12, 2015 | 04:34 PM
Thor'sHammer's Avatar
Thor'sHammer
Ummmm, start the truck and follow the stream. Pretty self explanatory.
Old Oct 12, 2015 | 07:03 PM
Greenlawnracing
That's the problem. I ran it for a while and see that is pooled up - but can't locate the source.
Old Oct 15, 2015 | 10:55 PM
Greenlawnracing
welp, appears to be the water pump as opposed to some simple fixes I was hoping for. May have to bite the bullet and take it to the local shop due to time constraints.
Old Oct 16, 2015 | 07:17 AM
wrvond's Avatar
wrvond
In today's vehicles, I doubt there's such a thing as a simple fix...
Old Oct 16, 2015 | 07:42 AM
Diamnd1's Avatar
Diamnd1
You got that right!! Never CHEEP either.
Old Oct 16, 2015 | 07:51 AM
00F350XL's Avatar
00F350XL
I have the same issue, but for mine its the hose off the reservoir. I just need to replace that hose. Id look there or your water pump.
Old Oct 16, 2015 | 09:02 AM
Greenlawnracing
I caved and am paying $500 to have it replaced with an Motorcraft pump, would have been about $100 less w/ an aftermarket. Just don't have the time right now, although after watching a video it appears to be a job one could do with an entire day and some patience.
Old Oct 16, 2015 | 09:28 AM
andym's Avatar
andym
I did it myself. It's not that bad on a 7.3L. It took me a weekend but I also flushed the engine. I followed this procedure: https://www.ford-trucks.com/forums/9...formation.html
It really is better to do it yourself if you plan to do keep the truck a long time. A shop wouldn't have taken the time to do the job right, like I did. If they did, it would have cost a fortune. For $500, all they're doing is draining it, replacing the pump, and filling it back up with whatever coolant they have laying around. A half-assed job, in other words.
Old Oct 16, 2015 | 10:06 AM
Topglock's Avatar
Topglock
Not a tough job on the 7.3. A few hours if everything cooperates. I did one on my 2000 F-250. Flushed and replaced fluids, thermostat, serp belt, etc. cost was about $350, using all ford stuff. Before you start, though, have the system pressure tested and verify the pump is leaking.
Kdawg89
Dec 19, 2021 09:01 AM
Special Ed
Jan 23, 2013 04:07 PM
cfietze
Jan 27, 2012 12:52 AM
cdrmotorsports
21
Nov 3, 2010 06:43 PM
first truck
Jul 29, 2009 09:02 AM
