Coolant Leak Help
Old May 30, 2021 | 03:30 PM
Whitey5.0's Avatar
Whitey5.0
Coolant Leak Help
Need a little help tracking down a coolant leak. It doesn’t appear to be coming from the water pump, hoses, thermostat, or radiator. I found the drip (in the pic below) but so can’t really see above it. Can these hardlines leak or is there something above it I need to contort and check? This is the front passenger side of the engine.
Old May 30, 2021 | 03:59 PM
R&RFord's Avatar
R&RFord
those hard lines are transmission cooler lines, so no engine coolant or you would have larger issues. The engine fan will blow coolant all over the place making it difficult to find leaks... You can try a pressure tester and then you don't have to contend with moving parts and heat.
Old May 30, 2021 | 04:11 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by R&RFord
those hard lines are transmission cooler lines, so no engine coolant or you would have larger issues..
Yep. No coolant leak from those lines. That leak is coming running down from somewhere else. I suggest you look at the water pump/ timing cover area.
Kdawg89
Dec 19, 2021 09:01 AM
k_conner
Jul 22, 2011 07:15 AM
Windsetter
Aerostar
18
Nov 21, 2010 03:29 PM
wildboar
1978 - 1996 Big Bronco
Dec 19, 2004 08:58 AM
