coolant leak
Old Dec 2, 2006 | 10:19 AM
leitrum's Avatar
leitrum
coolant leak
hey guys, i have a mistery coolant leak. i've checked all the hoses, an the water pump. the thermastat housing looks dry too. i was lent a radiator preasure tester and the system leaks, but its up above the cross member. even with a flash light i can't pinpoint. has anyone had this problem, and can shed some light on this leak. sorry its a 88 f150. thx tim
Old Dec 2, 2006 | 11:50 AM
bustech81's Avatar
bustech81
have you tried pressure testing your rad. cap. if the cooling system cannot maintain proper pressure,it lowers the boiling point of the coolant. and depending on your antifreeze to water dilution, coolant could be steaming out and you would never see it.
