Another trans problem😬
Old Jun 11, 2021 | 08:32 AM
  #31
IHateCommieCars's Avatar
IHateCommieCars
Yeah, my idea would have been good to try before he ever bought the Pioneer part, if you wanted to confirm the problem before spending the money.
Old Jun 12, 2021 | 09:27 AM
  #32
F350 1990's Avatar
F350 1990
Originally Posted by bismic
Those temps look ok. I believe I see up to about 175. The filter in the pan usually doesn't need to be changed. I changed mine at 150k miles "just because". The external filter is the one that needs to be changed, at least every 30k miles. I do it every 20k miles. Hopefully a transmission expert will come along and provide you with some specific direction.
Mark - flows to that external filter are really unimpressive, not sure it even does much but have seen many clogged / filthy from not being changed ever.
I'm with you on grounds -- always run voltage drop tests on the ground, also look for voltages elsewhere in places they shouldn't be.....these trannies (rock solid citizens as far as I'm concerned) do a re-learn, not that fast in some instances.
Old Jun 12, 2021 | 09:36 AM
  #33
TooManyToys.'s Avatar
TooManyToys.
That depends on the fluid temp, how open to the cooler. 10 to 80 minutes for the pan volume. You can extrapolate that out for the full quantity of fluid in the trans. But every week the full trans fluid is being polished unless you are sitting at home.
Old Jun 12, 2021 | 09:40 AM
  #34
bismic's Avatar
bismic
It is a bypass filter, so you are right in that it loses some effectiveness because of that. I can't recall the % of the circulated flow that is directed to the bypass filter, but as in all bypass filters it is a rather small percentage. Even so, bypass filtration is an effective design practice as the circulation rate will result in a very high percentage of the total fluid volume being filtered in a reasonably short time. It protects against a slow build up of solids, but not against solids generated by catastrophic failures.
That said, it is the only true filtration you have. It is imperative to keep it changed. These solenoids absolutely need clean fluid.
If someone wants better filtration, then they need to install the 08 pan and filter setup. I probably should have done that years ago, but at approx 232k miles (more than half of it with some heavy tunes), and still on the original transmission, I will probably just keep doing what I am doing. I'm just not driving it as much anymore.
Old Jun 12, 2021 | 09:45 AM
  #35
F350 1990's Avatar
F350 1990
O O What a Joke parts are not to be trusted, I'd also instrument for a overall line pressure check (with gauge) , also monitor the commanded pressures (and related amperages) for these PIDs given swaps:
SSPCA
SSPCD
and LINEDSD -- commanded line pressure (0-300psi)
Old Feb 6, 2022 | 11:51 AM
  #36
wynnjordan22's Avatar
wynnjordan22
05 powerstroke
Did you ever figure out the issue? I’m having the exact same problem
dtherrien
Nov 4, 2019 05:41 AM
Pastor Jared Parmley
Jun 8, 2019 09:21 AM
pud
Jan 1, 2016 12:19 AM
Unrealo4
Mar 31, 2013 10:11 PM
Bergerson
May 31, 2010 10:49 PM
