Sponsored by: Real Truck
2016 Transmission Shifting
Old Nov 3, 2019 | 05:13 PM
dtherrien's Avatar
dtherrien
My 2016 f250 4x4 6.2 with 72,000 mile just started having an issue with shifting the transmission. Backing out of the garage in the mornings from reverse to drive and in drive the transmission automatically goes into 5th gear and will not move until i go to reverse again. As soon as drive it goes back to 5th.
If i shut the truck off and restart it will work fine. So its been doing this about once aweek.
Brought it to the dealer and they couldnt find anything wrong after keeping it a couple of days to drive it..no charge though.
I tow daily with the truck and change the trans fluid a couple times a year with one being with a filter.
To me it seems electrical.
When it gets all funky the trans wont do anything other than reverse...so manual does nothing or tow haul mode does nothing...it stays in 5th or reverse works.
Old Nov 4, 2019 | 05:21 AM
senix's Avatar
senix
Probably need to take it to a trans shop and demonstrate for them.
Why do you change the trans fluid so often?
Old Nov 4, 2019 | 05:41 AM
dtherrien's Avatar
dtherrien
OCD I guess because I tow five days a week all year long. But it's only what's in the pan... 8 qts.
I know a good transmission guy. I figured I would let the dealer try in case of a TSB.
But reading thru other threads I'm thinking the issue is the shift selenoids. Seems to be a common problem.
Unrealo4
Mar 31, 2013 10:11 PM
RhondaBruce
Oct 7, 2010 06:48 PM
plowin4u
Dec 30, 2009 08:04 PM
lifted77f250
Jun 15, 2009 09:26 PM
t802950
1997 - 2003 F150
Aug 14, 2007 12:35 AM
