Bad Injector Disconnecting Consequences
Old Jun 5, 2021 | 10:43 PM
stress jelly's Avatar
stress jelly
Ok, so I have a 2005 6.0. I have a bad injector and was wondering if disconnecting it would get the ficm and if not, what would be the easiest way to disconnect it. Btw, I have the code and it’s cylinder 4. Any advice or info would be great.
Old Jun 5, 2021 | 11:28 PM
xcrsp440's Avatar
xcrsp440
When you get a new injector purchase it through a Ford dealer.
Old Jun 5, 2021 | 11:37 PM
stress jelly
alright, and that’s thought motorcraft right? And any ideas if disconnecting it until that injector gets shipped will fry the ficm?
Old Jun 5, 2021 | 11:57 PM
xcrsp440's Avatar
xcrsp440
I can’t help you with the FICM advice, but Motorcraft is not the same as purchasing from a dealer. I image it will set a DTC, possibly a check engine light too.
Many counterfeit or poorly rebuilt injectors are found all over the internet.
Best to purchase through a Ford dealer, not just someone who sells Ford remans.
Old Jun 6, 2021 | 03:59 AM
Hartwig's Avatar
Hartwig
Have you done a buzz test? If the injector does not respond, unplug the injector and plug in a new one. Now repeat the test. Usually the injector is the problem.
Old Jun 6, 2021 | 02:56 PM
Yahiko's Avatar
Yahiko
When you are ready to replace parts give Ed a call >>> https://www.ficmrepair.com
They sell real Ford parts and have access to other good parts. Also Ed and his staff
at FICMrepair are very good at support before, during and after the sale.
Ed started here just like the rest of us and found a fix for FICM issues and grew from there.
Old Jun 6, 2021 | 03:52 PM
BLADE35's Avatar
BLADE35
Are you suggesting that you are going to drive it with a bad injector just by unplugging it
Old Jun 6, 2021 | 05:01 PM
stress jelly
yes unless it is going to do something bad. I’m worried about it flooding the cylinder and I need to get to work somehow lol
Old Jun 6, 2021 | 06:59 PM
BLADE35's Avatar
BLADE35
not a good theory to rely on it may flood unplugged in my mind
Runaway comes to mind
Is it smoking already
Or is injector electronically fail only it may work
risk reward.
Old Jun 6, 2021 | 09:09 PM
bismic's Avatar
bismic
It will not damage the FICM if you run it with one injector unplugged. That said, I agree with the above ..... I wouldn't want to run an engine on 7 cylinders. Not for very long anyway.
Old Jun 10, 2021 | 07:55 AM
stress jelly
risk reward.
hmmm, alright, it isn’t smoking but I have a rough idle and rough ride at 55 mph. I do have the code as well so I’m gonna check the harness before I start anything major
Old Jun 10, 2021 | 07:56 AM
stress jelly
alright, I appreciate the response. I suppose I’ll just wait until I can get the injector 👍
mkingz
Dec 16, 2015 03:46 PM
David7.3
Jul 8, 2014 07:04 AM
Bigballzz
Mar 8, 2011 08:53 AM
gmhorse
Jan 27, 2010 06:41 PM
creed7276
Nov 20, 2008 09:06 PM
