Front brake/caliper help
Old Jun 1, 2021 | 08:18 AM
Bobdpt's Avatar
Bobdpt
I have a 2011 f250 6.7 diesel and pull a 34 ft travel trailer. Every year I have to replace the right or the right and left front calipers because they stick. Is there anything I can do to up grade my brake system? Master cylinder, calipers? I put slotted rotors on this year hoping it would dissipate the heat.
Old Jun 1, 2021 | 08:26 AM
djousma's Avatar
djousma
Are you doing the repair yourself? If so, are you pulling apart the caliper slide pins, cleaning, and re-lubing those? they make a rebuild kit with new rubber boots, and lube.
Old Jun 1, 2021 | 08:52 AM
The Bone's Avatar
The Bone
Are you using OEM parts? If you don't drive your truck when you tow then you should put synthetic brake fluid in the system. here is the brake tool I use to bleed the brakes.https://www.summitracing.com/search/...r-bleeder-kits
Old Jun 1, 2021 | 09:01 AM
djousma's Avatar
djousma
more questions.....do you find yourself burning through brake pads as quickly too? If so, I'd question whether or not you have your trailer brake controller gain turned up high enough? Generally speaking when towing, a stop should feel the same is when not towing with regards to brake control. It almost sounds like your truck is doing the bulk of the braking, and trailer not doing its job....
EDIT: I tow the 5th wheel in my sig, that is 16K loaded. I just replaced my front pads/rotors from original in fall of 2020 at 85K miles. The more I think about your situation is that your trailer brakes are not doing their job, and your truck is doing all the work - mostly the front brakes.
Old Jun 1, 2021 | 11:29 AM
Bobdpt's Avatar
Bobdpt
Thank you for the advice. Sometimes I do the work myself and sometimes I take it to garage across the street. I’ve greased the slide pins and did not make a difference. I usually get replacement calipers from advance auto parts or Napa. The trailer brake is turned up to 10 and feels like it is working. I may have to check out the trailer brakes to make sure they don’t have any grease on them.
Can you tell me if there is a big difference in brake/caliper size between the F350 and F250?
Old Jun 1, 2021 | 05:14 PM
djousma's Avatar
djousma
don't quote me, but I believe they are the same. As for trailer brakes, when on a side street doing 5mph or so, and you manually hit the slider on the brake control,, how much resistance do you feel? They should just about lock up if you move it fast.
Old Jun 1, 2021 | 05:19 PM
djousma's Avatar
djousma
Also, you can try a test, in a parking lot going slow, hold the slider for a good 100-200 feet, enough to heat the brakes up a bit. Then stop, and put you hands on each hub. All 4 (assuming tandem axle) should be about the same temp. You could have one axle brakes not working.
You could do same test with multimeter too, measuring amps at each wheel.
Old Jun 1, 2021 | 07:34 PM
Bobdpt's Avatar
Bobdpt
I think I did that with the trailer brake going 20 mph. And it stopped it in 20 ft I believe. I have to take the camper in to have something else looked. I’m going to have them check the brakes as well.
Old Jun 1, 2021 | 08:00 PM
Bobdpt's Avatar
Bobdpt
You are correct. I just googled same parts for front brakes for F250 and F350 for 2011.
Old Jun 1, 2021 | 09:18 PM
Work Truck Fanatic's Avatar
Work Truck Fanatic
What symptoms did you notice that lead you to look at the brakes?
Like others have said check your slides. Also check the caliper slide bolts and boots for proper lube and tearing. The best type of lube is AGS SIL-Glyde or similar. I also lube the contact points between both the brake pads and the caliper piston (moving part of the caliper) and the brake pad and the caliper clamp (stationary part of the caliper).
Check your brake lines also. If the inside lining breaks down, pieces of the debris can cause the caliper to stick if the pressure isn't allowed to bleed off when you let off the brake pedal.
Old Jun 2, 2021 | 05:20 AM
Bobdpt's Avatar
Bobdpt
I just put front rotors, brakes and calipers on 2 months ago. I’ve pulled our travel trailer 3 times. The latest trip was to TN from WV. When I got off the exit to come home, I stopped and turned right. The truck pulled to the right. I drove about 200 yards stopped, turned left and the truck pulled left. I feathered the brake and it drove straight. No issues with pulling to right or left the next morning driving the kids to school. I figure something is sticking with the brakes.
I have not lubed anything on the calipers since they are new but May this weekend. I usually do the slide pins and where the metal clip holing the brake that touches the caliper. I never thought about lubing the pistons. So I assume you push the brake to make the piston come out, lube the piston and push it back in? I will try the silicon lube you recommended. I appreciate all of the advice.
Old Jun 5, 2021 | 01:32 PM
tradosaurus's Avatar
tradosaurus
I use caliper grease only on the caliper pins and anti-seize lubricant on the metal back plate and on the contact points between the new rotor and the hub.
Old Jun 6, 2021 | 02:16 PM
Work Truck Fanatic
using AGS SIL-Glyde on the pads contact points will work also but may require more frequent checking. I don't like using anti seize, specifically on the piston side because SIL-Glyde is easier on the rubber components specifically the piston boots, at least that is what I was taught (I am always open to learning more). I have used AGS Cerami-Glyde Brake Lube as it is rated for higher temps and requires less frequent checks. Both AGS products are safe for use on all parts. That being said anti seize works also I'd just keep and eye on the piston boots.
MuddyWaters
Oct 2, 2010 02:24 PM
rmalottwtes30
Sep 19, 2010 03:02 PM
truckman87
Mar 18, 2009 11:37 AM
F250maniac
Aug 17, 2008 07:20 PM
hyperpunkguy[F150]
Mar 1, 2004 06:11 PM
