I have recently bought the upfitter switch for my 2006 king ranch that did not have it from factory. I was under the impression that all the truks were wired for it but was wrong, however i did find the part number from ford for the relay box and wiring (6C3Z-14A303-A). The problem is that it is no longer availible from anywhere. Does anyone know where i can get one or at least the connector ends that connect to the upfitter switch and fuse pannel?
Welcome to FTE
I was going to say the same thing Visureveyor said, pretty much sure but i think it is for the 08-10, but it might work without or with minor hacking
I just did a search on Google and that comes out to be for a 2010 year and I found it on A1 auto.
They list is as not fitting a 2006 F350.
Here is the link I used. Maybe check with them to see if they have the part. https://www.1aauto.com/2009-10-ford-...a/i/fdzwh00009
I bought the switches for the 06, and I got the wire harness 14A-303 . Everything plugged right in. The lights on the switches light up , but I don't have power to all the blunt wires.
Not sure if this is still active or not, if so.. does anyone know the possibility/difficulty of pulling & reusing factory relay box, harness, and switches? I have a junk truck with the upfitter cluster i want to transfer to my personal. 2006-2005 swap
It should be a simple plug and play going from 2006 to 2005. It was the same kit for 05 to 07.
