Need help
Old Oct 20, 2022 | 08:21 PM
Jimgodlove's Avatar
Jimgodlove
3rd Gear
Need help
[size=16px]Hey guys, I have a 2006 f250 6.0. Truck died while making a right turn. Now it will crank but not turn over. Since then, I have replaced batteries, Boost Seloniod, ICP and wiring harness, crankshaft position sensor, air filter, both fuel filters and nothing. Before that replaced all injectors and glow plugs. Had a/c coil serviced before this happened. Noticed the MAP behind the coil was not plugged in. Plugged it in, $1,000 in parts later then it started, but took a while too start. Next day is when I got it started. Drove it home and it died. A few days before it would die coming to a stop at a stop light. Then crank back up after a few tries. I'm thinking of checking FCIM and IPR next but broke as a joke now. Any suggestions?[/size]
Old Oct 20, 2022 | 09:47 PM
2001F350dualwheel's Avatar
2001F350dualwheel
Do you have any codes and do you have a bidirectional code tester/reader?
Old Oct 20, 2022 | 09:56 PM
Jimgodlove's Avatar
Jimgodlove
3rd Gear
Thank you
The codes showed the Map, cps, and boost selinoid A. That's it. All the auto part stores here said it was the boost selinoid. As of now, no codes I know of.
Old Oct 20, 2022 | 10:38 PM
2001F350dualwheel
If you were local in SoCal I could plug in my Autoenginuity and get some diagnostic reading. I would stop throwing parts at it man. Get the tools to diagnose these things.
so after the repairs those MAP CPS and VGT solenoid were still in memory? Or these were new codes after repairs?
Old Oct 21, 2022 | 02:45 PM
kbeefy's Avatar
kbeefy
The parts stores are just for selling parts.
Get forscan and a obdII adapter or forscan lite and an OBDII adapter or just get a scangauge II, any of those are better and relatively cheap.
Check Fuel pressure.
Without data your just guessing.
Old Oct 21, 2022 | 03:40 PM
Motohead911's Avatar
Motohead911
DO NOT GET A SCAN GAUGE II.
Do get an OBD dongle and get Forscan. Those are the best bang for your buck about $30 and you have a near factory level diagnostic tool.
Before you spend any more money or time you need a good quality reader.
xcrsp440
Jul 23, 2024 01:05 AM
Eoin Harland
May 15, 2022 02:42 PM
catalinaflyer
Jul 19, 2014 05:37 PM
idahodisco
Mar 23, 2010 05:50 PM
texans
Nov 19, 2009 02:55 PM
