Contura switch wiring
Old Mar 1, 2011 | 05:07 PM
JT250's Avatar
JT250
I have a SPDT Contura switch. Anyone know how to wire it. It has 4 terminals on the back 1,2,3,4. It is illuminated and would like it to light up when the respective position is selected. Looked on their website, but it is jibberish to me. Thought someone has done this before and could help me out.
Old Mar 1, 2011 | 05:14 PM
SpringerPop's Avatar
SpringerPop
What "series" of SPDT switch is it in their catalog, "J" or "V"?
Pop
Old Mar 1, 2011 | 05:16 PM
JT250's Avatar
JT250
V it says "V6d1" on the side
Old Mar 1, 2011 | 05:31 PM
SpringerPop
Well, a V6xx makes sense, as that is a SPDT, CENTER OFF, in the book, but it shows as having only three NUMBERED terminals, and four more un-numbered (for the illumination).
What are you going to use it for? That will determine the hook-up.
Pop
Old Mar 1, 2011 | 05:37 PM
JT250's Avatar
JT250
Wanting to have two options for my "trailer tow battery charge" wire in my 7 pin. I want to have a stock (on with key) and a constant hot. I am using it for my interior trailer lights and dont want to go turn the key on every time I want the lights on. After looking at it again it looks like this.
8 7
2 blank(5)
3 blank(6)
Does that make sense?
Old Mar 1, 2011 | 05:43 PM
SpringerPop
No. No sense.
Describe where in their catalog you are looking.
I understand what you are attempting to do, and I believe it's do-able, but we need more info on what the switch looks like.
Pop
Old Mar 1, 2011 | 05:53 PM
JT250's Avatar
JT250
not looking it catalog. Looking at back of switch. I dont really know how else to describe it. Ordered the switch online. I used to have them for my ARB locker that I had on my ranger and I have seen a lot of people use them on here. I am thinking that I can cut the wire going to the trailer connector after the fuse panel. I will then connect the cut end of the wire that goes to the 7 pin to one of the terminals. Next I will connect the cut end coming from the fuse to the first "on" position and then connect a "constant hot" wire to the second on position.
Old Mar 1, 2011 | 06:01 PM
SpringerPop
I'd do it completely different.
I'd do it with the existing Trailer Battery Charge relay, and break open the wire (I show it as a Black wire with yellow tracer) from "ignition on" to the relay coil.
Wire the "common" back to the relay coil, with one position to the previously cut wire, and the other to "constant hot".
That keeps the trailer "battery charge" circuit fused for safety.
If you can take a photo of the back side of your switch, I can help you further, but I've gotta' see it, as your description isn't registering in my mind's eye.
Pop
Old Mar 1, 2011 | 06:06 PM
JT250's Avatar
JT250
Hopefully this pic is good enough.
https://www.ford-trucks.com/forums/m...bums-misc.html
Old Mar 1, 2011 | 06:08 PM
JT250's Avatar
JT250
Sorry pic didnt work, but the link is there to the pic. I will have to figure out how to make the pics work later. Got to run for a little bit, will check back later.
Thanks for the help
Old Mar 1, 2011 | 06:17 PM
SpringerPop
OK, that will work. There appear to be FOUR rows of pins, with the upper-most being smaller.
Fill in the pin numbers where I use the term "something" below:
blank -------- something
something ---------- blank
If you look here, you'll see that they don't appear to use the number "8" in the Contura series, which has me confused.
Pop
Old Mar 1, 2011 | 06:48 PM
JT250's Avatar
JT250
Pop I know you said they dont use 8, but I swear that is what it says.
Blank_____7
8_____Blank
2_____Blank
3_____Blank
BTW the pic is in my album and I pasted the link in the box after clicking "instert image" do you know what I am doing wrong?
Old Mar 1, 2011 | 06:54 PM
JT250's Avatar
JT250
Is the relay you are referring to in the fuse box? On my 03 all of my fuses are under my dash.
Old Mar 1, 2011 | 07:38 PM
SpringerPop
My relay is in a separate "doghouse" adjacent to my under-hood fuse panel, which yours doesn't even have.
I'll have rely on someone with your year to chime in here to let us know where to find that relay.
I had no problem seeing your photo. Can you take one of the other side so I can identify the series of switch? The ones I'm looking at don't have an "8" at all.
Pop
Old Mar 1, 2011 | 07:56 PM
JT250's Avatar
JT250
I see what you mean about there not being any 8's. There are some on the second page of that diagram, but none of them are the same numbers as mine. I am working on more pics.
