Crank no start
Old May 17, 2021 | 06:28 PM
Bvretn1's Avatar
Bvretn1
Crank no start
Alright, this truck has me stumped. I have a 1988 F250 with the 5.8L that cranks and doesn't start. Here's a bit of background.
I purchased the truck several weeks back. The owner let it sit for 15 years and decided to sell it, so we brought it home on a flatbed. First thing I did was put a battery in to see if it cranks, which it did.
I then put some fuel in the intake to see if it would fire up, which it did. Once I knew it would start and run, I bought a new fuel tank, pump assembly for the tank, high pressure pump, and fuel filter. Got those installed, put fresh fuel in and went to start it and nothing. Not even a pop like it wants to start. So I put some fuel in the intake again to see if it would start. Nothing. Doesn't even pop.Next step, I pulled a plug to see if there is spark and there isn't spark.
I installed the above parts and didn't mess with anything else, so I'm not sure why there isn't spark now when it ran the first night getting it home.
Any suggestions on where to look next?
Old May 18, 2021 | 08:35 AM
jas88's Avatar
jas88
Make sure you have 12V+ at the coil with they key on.
Old May 18, 2021 | 05:02 PM
Bvretn1's Avatar
Bvretn1
Ok, I narrowed it down to the ICM, which brings about my next issue. In order to change out the ICM, the distributor needs to rotate counterclockwise, yet it is seized like a mother. I've spent the last 3 hours heating, spraying PB blaster, and prying on this thing to try getting it broke free. Well, I heated, sprayed, and pryed one last time and cracked the distributor housing towards the block.
Any ideas on how I go about removing the distributor now?
Old May 18, 2021 | 07:17 PM
Bvretn1's Avatar
Bvretn1
Spent another hour heating and using PB blaster and the distributor still will not break free. Getting fed up with this, I put a strap around the distributor and tied the other end to the bucket of a skidsteer thinking it has to break free now. Nope. Not even dancing the front end of the truck around for several minutes broke it free. This is insane!
Old May 18, 2021 | 07:37 PM
SFaulken's Avatar
SFaulken
Unfortunately, not uncommon. Just takes patience and pressure. Sometimes it can take a day or two of f*&king with them and soaking them down with penetrating oil
Old May 18, 2021 | 07:39 PM
spurredon's Avatar
spurredon
Check out the end of this link for your stuck Disty. Stuck Distributor: the final "solution"... - Ford Truck Enthusiasts Forums (ford-trucks.com)
Old May 18, 2021 | 07:58 PM
Bvretn1's Avatar
Bvretn1
Originally Posted by spurredon
Off to the store. It's raining and cold, so I'll try it tomorrow and let you know how it works. Two bottles of gas and a can of PB Blaster trying to get this SOB out.
Thanks!
Old May 19, 2021 | 08:50 AM
jas88's Avatar
jas88
Use a mix of 50% ATF and 50% Acetone. Works much better than PBB or any other penetrant for that matter.
Old May 19, 2021 | 03:05 PM
Bvretn1's Avatar
Bvretn1
I'm gonna try this out next as round 4 of the lye solution isn't working...just put round 5 on. Nine hours of dicking with this thing now 🤬
Old May 19, 2021 | 03:29 PM
sandymane's Avatar
sandymane
I have been following this and researched a little. The most common thing I found is the dizzy must be able to turn before you can pull it. 50/50 Acetone and ATF were mentioned as was above to be the best lubricant to soak with in the information. The last thing I read that worked is a hammer and a chisel. These were all different situations.
Old May 19, 2021 | 04:34 PM
Bvretn1's Avatar
Bvretn1
I have a feeling the motor is gonna have to be yanked to pound it out from below. Really hate to do that; however, after 6 hours of soaking, heating, and beating on it yesterday, and 4 hours today repeating a soak in lye solution and beating, I'm thinking the worst. Just got trying to pull it with the skidsteer again with no luck. Next is the ATF/Acetone mix, which I'm gonna start trying here in the next hour.
Old May 19, 2021 | 04:45 PM
sandymane's Avatar
sandymane
The article about the ATF and acetone said let it sit for 24 hours.
Old May 20, 2021 | 07:08 PM
Bvretn1's Avatar
Bvretn1
I tried the 50/50 mix of acetone and ATF and let it soak for 18 hours. Still won't budge. Spent another 6 hours today trying to break it free. I'll keep trying for a few more hours this evening, then call it quits.
Old May 23, 2021 | 03:19 PM
Bvretn1's Avatar
Bvretn1
Drilled about 10 holes in the distrubutor casing to crack the upper half, and she pulled right out. I win🙂 💪
Old May 23, 2021 | 03:36 PM
sandymane's Avatar
sandymane
Glad you got it and followed up.
