Electric fan conversion
Old Jun 3, 2021 | 10:33 AM
  #31
Chris Rudeau's Avatar
Chris Rudeau
i didn't like what i read about everyone having issues with over heating and wiring issues. plus everything i read said the mechanical fan from an 01 explorer moves a ton more air. so i swapped the whole motor, front dress and all into my 84 lol. I'm running a 2001 4.6 f150 fan and used a piece of flat stock to extend the housing. its also a 96 radiator and condensor mounted in there. still wiring it all up but she finally starts and moves!!! yay. This is the only pic I have that kind of shows it
Old Jun 3, 2021 | 12:56 PM
  #32
EB5.0's Avatar
EB5.0
If I read the posts correctly the best temperature for the fans to come on is around 200-210. Then they shut off between 195 and 200. Am I correct?
Old Jun 3, 2021 | 12:57 PM
  #33
EB5.0's Avatar
EB5.0
I'm running a stock 195 thermostat
Old Jun 3, 2021 | 08:51 PM
  #34
6.9idiatsturbo's Avatar
6.9idiatsturbo
Originally Posted by Imagemineye
I got the biggest stock alternaator I could at NAPA, a whole whopping 85 amps... I am definitely going for 170 or 200 once i get subwoofer.
What do you think the minimum is that I could get away with, without the sub that is?
do you know if I need the 6 and 13 oclock , what is it, g3 conversion? I am currently setup for 2 and 6 Oclock but it looks like I have provisions for noon and 6
power*******s.com (b a s t a r d s) is where I got my 220 amp 3g alternator from.
Old Jun 12, 2021 | 08:46 PM
  #35
EB5.0's Avatar
EB5.0
Originally Posted by EB5.0
LMC truck has an A/C relay harness for the electric fan conversion. It will be delivered Monday, so I will let you know how it works. It allows you to not have to cut your factory wiring.
The LMC truck ac relay harness I could not use. It is its own controller itself for only the AC. The relay harness I got was from National Parts Depot. It was the Derale dual fan relay. I has an adjustable temperature probe and a wire for the AC. There is a big difference between a cheap relay harness and a good quality one. Before the cheap one that came with the fans drew alot of power so at idle, my alternator wasn't charging very well. With the Derale harness, my alternator works fine, and I can tell the fans blow more air that with the cheap harness.
Old Jun 14, 2021 | 11:22 AM
  #36
Mikulh's Avatar
Mikulh
I had mine coming on at 200 and back off at 195. Someone here said that range was too close, so I bumped it up to come on at 203 and off at 195. Honestly I've had no issue with either one and my fan doesn't cycle on and off a too quickly (in my opinion). I just don't see the point of turning the fan on when the thermostat isn't even open yet (195 degree thermostat). Supposedly you get your best power and mileage when at operating temp... I'm getting 16mpg with my 5.8L, which I consider good mileage for a 351w.
Old Jun 17, 2021 | 09:33 AM
  #37
Toork's Avatar
Toork
do you have a link for the fan controller?
Old Jun 17, 2021 | 01:06 PM
  #38
EB5.0's Avatar
EB5.0
Yes, I will post it later today.
Old Jun 17, 2021 | 06:11 PM
  #39
Toork's Avatar
Toork
I just ordered a Taurus fan and a Volvo 2 speed fan controller. Now I need a dual temp sensor. BMW makes one that comes on at 195* and 210*. Is 195 to early or not that big a deal.
Old Jun 17, 2021 | 06:30 PM
  #40
EB5.0's Avatar
EB5.0
https://www.npdlink.com/product/adju...-switch/135802
Here's the link. The picture is old. I have the new design.
Old Jun 17, 2021 | 10:28 PM
  #41
Toork's Avatar
Toork
the description says it works with dual fans. I wonder if it would work with my 2 speed fan. It’s only sending a on/off for designated temps. My Volvo harness will control the actual power supply. Might be a winner!
Old Aug 26, 2022 | 07:27 PM
  #42
dremtofford's Avatar
dremtofford
how can you tell the difference between a 95 amp 3g and a 130 amp 36?
Old Aug 26, 2022 | 07:34 PM
  #43
AuroraGirl's Avatar
AuroraGirl
one has the mounts at 12 and 6 and one has it at 3 and 6 kinda. Smaller physically (95) and:
foreground=130 right one = 95
RadioControlGuy85
Oct 7, 2016 10:17 AM
TheFoum913
Dec 29, 2013 01:11 AM
De-von Ford trucks
13
May 15, 2011 02:16 PM
maddogken
Aug 30, 2009 06:05 PM
mirrored_iceman
May 6, 2003 09:11 PM
