Transmission Fluid
Old May 12, 2021 | 04:52 PM
okiefordpower's Avatar
okiefordpower
Transmission Fluid
I have a 1993 F-250HD 7.3 N/A Diesel with the E4OD Auto Trans. It originally used MERCON Fluid. ......Lots of MERCON Part Numbers now.....What is the correct, Ford recommended Trans. Fluid for my Truck?
Old May 12, 2021 | 04:55 PM
ford390gashog's Avatar
ford390gashog
That would be Mercon V. Mercon is no longer licensed or acknowledged by Ford and died off in 2006.
File Type: pdf
Old May 12, 2021 | 04:58 PM
okiefordpower
Thank you!
Old May 12, 2021 | 05:06 PM
GoinBoarding's Avatar
GoinBoarding
Mobil 1 full synthetic ATF that's Mercon V spec has been working well in my truck. I've been changing it between 50-60k miles. Now at 323k miles and just keeps going.
I recognize it's more than likely the fact that I change it at all, and not the fluid brand itself, that is aiding the longevity.
Old May 12, 2021 | 05:27 PM
okiefordpower
Thanks for the info!
Old May 12, 2021 | 05:28 PM
okiefordpower
Thanks for the TSB! Just what I needed!
mikerans
Mar 5, 2012 02:01 PM
gsmoljan
Mar 5, 2011 06:13 AM
Geotruck
Aug 15, 2010 06:28 AM
96powerstroke
Jan 16, 2006 05:32 AM
Bear1971
Mar 17, 2003 07:53 AM
