Glow plug module
Old May 10, 2021 | 04:44 PM
bwguardian's Avatar
bwguardian
Glow plug module
So I'm going to be getting some things done on the wife's Excursion and need to order some parts. The CEL has been on for a while with a glow plug code...I can clear it and it takes a couple crank ups then comes back. When I took it off you can see the issue in the plug and the module. I've read where the connector prongs on the plugs need to be spread apart. Is there a way to test the module and/or plug to see if they in fact need to be replaced?
^^^...Plug in connectors...
^^^...Glow plug module...
Old May 11, 2021 | 02:41 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I'd assume the GPCM is bad. Female bit of the connector might be saved with a needle nose pinch, or install a new pigtail.
Old May 11, 2021 | 06:49 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
GPCM pinpoint test taken from the Ford Service Manual is attached.
Old May 11, 2021 | 10:36 AM
ScaldedDog's Avatar
ScaldedDog
FWIW, I did an autopsy on my failed GPCM a few years ago, and posted the results here. As you can see from this related thread, the symptom I was getting with a CEL with codes showing all for glow plugs on one side had failed.
Mark
kmcmurph
Jun 4, 2020 02:04 AM
david moore
Sep 10, 2011 12:33 PM
kjf-250
May 27, 2009 09:09 PM
powerglyde1234
Nov 7, 2005 10:31 PM
