glow plug control module
Old Aug 3, 2011 | 07:53 PM
david moore's Avatar
david moore
2005 6.0 1 ton dully 121,000 miles have had no other problems except the normal 6.0 oil leaks (LOL) problem..... no start -was traceing wires looking for chafeing or broken wires and found wire plugs that hooks to glow plug module ,wiggled and started up, several times i have had to wiggle the wires on the glow plug module to get my truck started. today wiggle wiggle and no luck ,module is hot after a few tries to start is this normal for this part and is there a way to test this part
Old Aug 3, 2011 | 09:06 PM
BLADE35's Avatar
BLADE35
yes its tested with an inductive amp meter and you can also ohm out each plug but sounds like you may need a new harness
23. Troubleshoot the glow plug system (you need a clamp on inductive ammeter). Test each glow plug module wire bundle separately, then test each glow plug. Look for any amperages lower on one side or lower to an individual glow plug. From each module you should see 200 A at first dropping quickly to 35-37 A if the GPCM is OK. Both modules should read apprx. the same. Each glow plug will draw 8-10 A. Or you could check the resistance in each glow plug - should be less than 1 ohm
Old Aug 14, 2011 | 12:22 AM
david moore
ty for the info , module ok,went thru no start list, ***flustrated *** . so i sent her to the diesel doc ....HPOP ,ipr ouch is all i can say
Old Aug 14, 2011 | 08:14 AM
cheezit's Avatar
cheezit
sounds more like icp sensor and connector then a bunch of that stuff. sometimes the dealer is cheeper.
Old Sep 10, 2011 | 12:33 PM
david moore
update
Bad engine harness
Blakshukvw
Dec 17, 2016 03:37 PM
kjf-250
May 27, 2009 09:09 PM
powerglyde1234
Nov 7, 2005 10:31 PM
