Electrical issues with my windows.
Old May 10, 2021 | 01:19 PM
David Fehir's Avatar
David Fehir
Any electricians in here? Yesterday my passenger side window stopped working in the down position... of course. I checked for power at the switch with a test light and I have power at the switch and coming out of the switch to the motor all the other windows work fine. So I changed the motor and still didn't fix it so for the hell of it I also changed the switch still didn't work. I also wanted to note that the switch on the driver side for the passenger side doesn't work either and after putting the new motor in I noticed the window would go down the rest of the way but not back up. Please help I have no ****ing idea were to go next. 03 super duty. Thanks.
Old May 10, 2021 | 03:51 PM
Yahiko's Avatar
Yahiko
Likely one of the door switches had gone bad.
I don’t recall if you can swap the right with the left
or not. But you should try that. If one switch
has gone bad that will make it so you will not
be able to use that function. When I get to a
place where I can access my diagrams I will
post them for you.
Old May 10, 2021 | 03:58 PM
xcrsp440's Avatar
xcrsp440
Any other strange electrical issues? Radio working ok, dash lights or gauges?
I believe a symptom of a failing cluster is malfunctioning windows.
Circuitboardmedics website lists these as the symptoms
  • Intermittent power to radio, power windows, or interior dome light
  • Intermittent power to all gauges
  • Dim cluster due to faulty backlighting
  • Odometer screen dim or completely out
Old May 11, 2021 | 06:52 AM
Tom Compton's Avatar
Tom Compton
Ground wire
I had a similar issue with the driver’s door on my Expedition. The ground wire was broken. Made a jumper and all is ok. Anybody need a window regulator motor for a ‘97 Expedition?
Old May 11, 2021 | 11:02 AM
troverman's Avatar
troverman
My driver's window has been acting strange. It will go down, sometimes seemingly binding halfway down and actually stop. At that point, the window switch will not allow the window to go up or down. Last weekend I used the "one touch down" function...window went all the way down and would not go back up. I removed the door panel; everything appeared find, I pushed / pried / shoved on the window and it went up again. Not sure if the master switch set on the driver's door is going bad, or if something is binding on the regulator, or what.
I thought these things had circuit breakers that could self-rest on the windows, instead of blowing a fuse during an overload?
Old May 11, 2021 | 03:35 PM
Tom Compton
What cluster?
Are there more than one cluster?
Are all of the above symptoms associated with one cluster?
which effects the radio power and which the dim due to faulty back lighting?
Thx
TC
Old May 11, 2021 | 03:51 PM
Visurveyor's Avatar
Visurveyor
They are talking about your instrument cluster, that you.look at as you drive. It is connected to a plethora of electronics. If it starts going bad it's like you have ghosts messen with ya.
Old May 11, 2021 | 10:55 PM
Yahiko's Avatar
Yahiko
That type of issue is do to a Accessory Delay relay going bad in the cluster.
That is what allows the windows and other things to work for about 10 minutes after you turn the key off.
TexasGuy001
Jun 11, 2016 09:44 AM
pathfindertango
Feb 20, 2015 01:20 PM
hapkidoman
Nebraska Chapter
Jan 17, 2009 04:25 PM
gad4wd
2004 - 2008 F150
Feb 18, 2008 10:33 AM
hugo0612
Sep 17, 2007 10:09 PM
