Wiper Switch Removal
Old May 9, 2021 | 01:14 PM
rpaxton939's Avatar
rpaxton939
What is the trick to removing the wiper switch from my 54 dash?
The book says to use the "Special" tool to unscrew the bezel after removing the ****.
Problem is.....How to remove the ****? Is it pressed-on or threaded onto the shaft?
Mine is very tight to the shaft and I don't want to break it or the switch.
Thanks for your help.
Bob
Old May 9, 2021 | 01:44 PM
abe's Avatar
abe
Without looking I think there is a small screw holding the **** on the shaft. Then the bezel screws out. I think you can screw it out with a small flathead screwdriver.... carefully.
Old May 9, 2021 | 03:10 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Like Abe said, there is a set screw near the base of the ****. It is the same for vacuum or electric driven wipers.
I took my switch out with a small flat screwdriver.
Second from left.
Here is a close-up of the nut:
Old May 9, 2021 | 03:45 PM
rpaxton939's Avatar
rpaxton939
Thanks Abe and EffieTrucker. There is a small set screw at the base of the ****. If it was a snake it would have bit me. It takes a very small Allen wrench and off it comes. Now for the "Special" 1954 tool. I found a small needle-nosed pliers that open when you squeeze the handles. It works good but that nut has 4 square slots that would be best used with that "Special" tool of yesteryear. Anyway.....switch is removed and I thank you.
Bob
Old May 9, 2021 | 03:48 PM
1954F100ranger's Avatar
1954F100ranger
Yep! I was typing as you said it. After the **** use the needle nose pliers in opposing grooves in the bezel.
Old May 9, 2021 | 03:58 PM
rpaxton939's Avatar
rpaxton939
I just looked at Mid Fifty. They have the "Special" tool! Part Number 80100. $9.95 plus a million dollars shipping (LOL)
If I get one, I probably will never use it. If I don't get one, I will wish I had it many times..........
Old Jan 14, 2022 | 03:49 PM
ingo's Avatar
ingo
Second from left.
does anybody know if this nut is still available?
Thanks
Old Jan 14, 2022 | 04:11 PM
52 Merc's Avatar
52 Merc
I have made my own "special tools" on many occasions by modifying the end of a piece of pipe or old, cheap deep socket, filing the appropriate teeth on the end to fit into the notches in the nut. It doesn't take much work and saves a ton of money, especially that million dollars shipping.
Old Jan 15, 2022 | 09:47 AM
5851a's Avatar
5851a
I have the special bezel tool and works great, have used it for years. Before that I used a snap ring tool with the 90 degree tips.
Old Jan 15, 2022 | 09:52 AM
EffieTrucker
Thanks
Mid-Fifty sells them:
1953-60 Ford F-100 Switch Nut Insert, Wiper Or Heater - B7C-17512-A (midfifty.com)
As does Mac's Auto Parts:
53-60 Pickup Wiper Switch Nut (macsautoparts.com)
And Dennis Carpenter:
Windshield Wiper Switch Nut for 1953-60 Ford Trucks | Dennis Carpenter Ford Restorations (dennis-carpenter.com)
They're all under $10, and probably made by the same company. Best deal will come down to shipping, which seems to be the case with most small items.
Old Jan 15, 2022 | 11:42 AM
abe's Avatar
abe
I used a small flat screwdriver and used a hammer to tap the screwdriver to the left to loosen the nut.
Old Jan 17, 2022 | 03:14 AM
ingo's Avatar
ingo
thank you much Effie Trucker
ERG4Life
15
Mar 17, 2024 11:25 AM
Badmrscary
Feb 15, 2011 04:57 PM
64F250
Feb 27, 2007 12:11 PM
Boltgunner
Sep 16, 2001 07:08 AM
fast freddie
1978 - 1996 Big Bronco
Aug 12, 2001 04:11 PM
