Wiper Switch Knob
Old Sep 15, 2001 | 07:34 PM
Boltgunner's Avatar
Boltgunner
Wiper Switch ****
How do you remove the wiper switch ****? 76 F-150
Old Sep 15, 2001 | 08:25 PM
77_f250_460's Avatar
77_f250_460
Wiper Switch ****
Old Sep 15, 2001 | 08:55 PM
71swissaqua's Avatar
71swissaqua
Wiper Switch ****
Not sure if it's the same but my 71 has a allen head set screw on the neck of the wiper ****. It's pretty small and hard to see. You might have to rotate the **** to see it. The light switch has the little botton on the switch itself you have to push in to get the stem to pull out. Hope this helps. Clint
Old Sep 15, 2001 | 09:42 PM
Boltgunner's Avatar
Boltgunner
Wiper Switch ****
Seems like there is something I have to push in on the **** to free it, but I cannot determine "what" I am pushing on. I have had this dang **** off before, and it is not secured with an allen screw, but some kind of spring steel piece that bites the shaft.
Old Sep 16, 2001 | 07:08 AM
lastchance's Avatar
lastchance
Wiper Switch ****
There is a little spring steel clip that holds it on. Make yourself a small steel hook, or maybe you can get in behind it with a small screwdriver, and pry the rounded end of the "D" shaped metal clip towards the **** while you are pulling on the ****. It will slide off easily.
