406 FE?
Old Apr 28, 2021 | 06:19 AM
caravaggio2000's Avatar
caravaggio2000
406 FE?
Spotted a 406 for sale near me. Do they have a different block casting number? All I see on this one is a 5 (as opposed to the 352). I've asked the seller for a pic of the bottom side of the block as I believe the 406 is supposed to have cross bolts. Will all the normal FE stuff bolt to this or is it like a 427 that has some of its own parts?
Old Apr 28, 2021 | 08:34 AM
440 sixpack's Avatar
440 sixpack
I've never seen a 406 but I know they have a 390 crank and an oversize bore. some were cross bolt but I don't believe all were. some were mechanical lifter only I'm not sure if all were that way.
It might be worth what he's asking or more. I'd ask about it on the FE forum there are some real FE gurus there who could answer all the questions.
Old Apr 28, 2021 | 08:48 AM
5851a's Avatar
5851a
Only the engines used in Nascar had crossbolts. The casting is there but they used regular 2 bolt caps from the factory. No drilled oil passages for hydraulic lifters. Will have the old 2 bolt motor mount holes, adaptable to later with some work but they don't just bolt in. May want to check casting numbers with 332-428 Ford FE Engine Forum
Old Apr 28, 2021 | 11:17 AM
mikeo0o0o0's Avatar
mikeo0o0o0
The 406 has the same bore as a 428, 4.130"
Old Apr 28, 2021 | 11:39 AM
ford390gashog's Avatar
ford390gashog
Well it looks correct, that's a solid lifter block that hasn't been drilled.
Old Apr 28, 2021 | 11:46 AM
caravaggio2000
So is there any advantage to this block vs. a webbed 390 block? I was hoping it was a 4 bolt main block, but since it is not, I'm not sure it is worth it. I see complete 390's all the time for around 500.
Old Apr 28, 2021 | 03:34 PM
ford390gashog
Well for 2k I would be all over it. The aluminum intake and exhaust is worth that. Now if the original dual point distributor was there it would be worth more. All 406 engines were mechanical lifter and only mated to manual transmissions.
Old Apr 28, 2021 | 04:38 PM
flowney's Avatar
flowney
Those cast iron headers are a plus as well. The 428 bore size would suggest a different and beefier block casting. Generally speaking one cannot safely bore a regular FE block that far.
Details from Wikipedia: https://en.wikipedia.org/wiki/Ford_FE_engine
You can see the evolution of the FE leading up to the 427.
Old Apr 28, 2021 | 05:36 PM
5851a's Avatar
5851a
It may not have the cast and drilled boss for alternator mount.
Old Apr 28, 2021 | 09:01 PM
DaveMcLain's Avatar
DaveMcLain
That block isn't drilled to have the pressure relief in the back like a center oiling 427 didn't the 390HP and 406 engine have the same thing?
Old Apr 29, 2021 | 03:00 AM
matthewq4b's Avatar
matthewq4b
Ya for $2000 you can not miss. I'd jump on that pronto.
Ask the seller for the block casting number right side of the block just ahead and below the core plug.
Here is all the info I have on the 406 block and the casting numbers. (See below) So you have some info going in as to what it is.​ Also, a​​​​ll of the cross-bolted blocks are heavier castings than the 2 bolt main blocks.
If the block casting numbers do not match any of the below it is not a 406. And it looks like the rockers are non-adjustable and IIRC all none of the 406's ran juice cams so I question the validity of it being an actiual 406.
If the block casting number does not match any of the below, post the casting number that the block actually has and I can tell you what it is/from.
C2AE-B – 62-63, 406, cross-bolted mains
C2AE-BD – 62-63, 406, cross-bolted mains
C2AE-D – 62-63, 406, cross-bolted mains
C2AE-J – 62, 406, 2-bolt mains, Solid Lifters, oil pressure relief at back of block
C2AE-K – 62, 406, 2-bolt mains, oil pressure relief at back of block
C2AE-V – 62, 406, 2-bolt mains, oil pressure relief at back of block
C3AE-D
– 63, 406, 2-bolt mains, has the cross-bolt bosses but no cross bolts
C3AE-V – 63, 406, Solid Lifters, oil pressure relief at back of block
Old Apr 29, 2021 | 05:07 PM
1browski's Avatar
1browski
Is that a big machining screw up at one of water jackets on the engine block in one of the pics? Or am I just seeing things.
Old Apr 29, 2021 | 05:13 PM
symonds86's Avatar
symonds86
I saw that too and wondered same thing
Old Apr 29, 2021 | 05:33 PM
kenny nunez's Avatar
kenny nunez
I know that 427s that were NASCAR engines had threaded pipe plugs in place of the press in core plugs. If this engine has them then all the better.
Old Apr 30, 2021 | 09:35 AM
5851a's Avatar
5851a
The pictures are confusing. Looks to be several different engines.
73 hi-boy 428 fe
Jun 3, 2020 12:44 PM
1browski
Jun 30, 2019 03:12 PM
gypsytpr
23
Sep 20, 2017 09:26 AM
Scotty Young
Nov 1, 2009 09:19 PM
