Hey guys, this is my first post, and it is about the brakes on my truck. I have been referencing this website for a while and figured it's time I started actually participating. Anyway, my 1973 f100's brakes have been acting real funny recently. About a month ago I replaced the front passenger wheel cylinder that had gone out and then bled them. After that they worked fantastically. The other day though they started sinking to about halfway before engaging. The weird thing about it is that it is random. Sometimes they work fine and other times they sink to halfway first. I would suspect the master cylinder but that is pretty new at about a year old. It is slightly leaking from the bottom though, but I can't figure out where from because the connections are dry and so is where it connects to the booster. Also, about a year ago both of my rear wheel cylinder's were stripped at the bleeder valves so I took it to a mechanic and instead of putting in new wheel cylinders he just tapped a new hole and put bigger bleeder valves in. there is a very, very slight leak around these. I know that is a lot of information, but if any of you guys can help me out I'd really appreciate it.
any leaking of brake fluid can cause issues. If the master is leaking, I would replace it. Wheel cylinders are cheap, no reason to try repairing them by drilling/tapping. Personally I wouldn't do any additional trouble shooting until the master and leaky rear wheel cylinders are replaced and the system gets properly bled.
I would also replace the one front wheel cylinder that hasn't been done. Also inspect the brake hoses front and rear for cracks and dry rot, replace as needed.
Replace all the wheel cylinders, including the ones with leaking bleeders in the back. Check the lines for leaks and kinks. Did the master run low on fluid while you did this? It might need bleeding too.
Also, it's not unusual for a master cylinder to start failing after bleeding the brakes. The extra pistol travel can stir up dirt/corrosion that weren't causing trouble before.
Thanks guys, I called the auto parts store and ordered a new master cylinder, and new wheel cylinders, springs, and shoes for the rear. When I did the front left wheel cylinder the springs and shoes basically fell apart, so I'm assuming that the rears will be the same way. Anyway, I really appreciate all the help and I will let you guys know the results as soon as I get it all replaced.
I’d go ahead and spring for new hoses, too. They’re not terribly expensive, and after those you can pretty much say the brake system is new. Last thing you want is to do all that work, then step on the brakes and a hose let’s go.
Take your time and bench bleed the master cylinder carefully. Make sure you have no air bubbles before you move to the truck. Make sure to have your fender properly protected, as brake fluid from the bench bleed will destroy your paint. You are doing the right thing in replacing brake parts. Always good insurance.
No matter the source of the hydraulic parts, lubed or not, the system will benefit from a flush/bleed done a minimum of every 5 years or so depending on your part of the country.
