Gauges not working
Old Apr 7, 2021 | 12:27 PM
GrandpasOldF250's Avatar
GrandpasOldF250
Gauges not working
Over the last few weeks I noticed my fuel and temp gauge working intermittently (1972 F250 w/390, C6). My oil pressure gauge hasn't worked in years and my ammeter is useless with my 3G swap. Now the gauges aren't working at all. Does this sound like it could be the instrument cluster voltage regulator?
Old Apr 7, 2021 | 12:42 PM
smoky_diesel's Avatar
smoky_diesel
Or the plug connection. Easy to diagnose, pull dash and;
1. wiggle connector.
2. ground the sensors.
3. measure regulator output.
Old Apr 7, 2021 | 01:46 PM
GrandpasOldF250
Ended up being the connector that goes into the interment cluster. Still no luck on the oil pressure gauge. I'm pretty sure the gauge its self is dead.
Old Apr 7, 2021 | 06:48 PM
smoky_diesel
Try grounding the oil sending wire at the engine block and see if gauge responds. It should swing to 'H'.
Old Apr 7, 2021 | 11:20 PM
GrandpasOldF250
No luck on that, even hooked up the multimeter and it gave zero reading. I even cleaned off the contacts on the instrument cluster. At least I have a brand new high volume Melling oil pump.
Old Apr 8, 2021 | 11:02 AM
smoky_diesel
Could be the old oil soaked wiring from gauge. Probe the posts on the gauge itself. Should have 5 ish volts on both sides, ground the one that leaves the cluster. If no power at gauge the connection to the regulator may be broken on the cluster.
7oldblue3
Mar 17, 2019 06:28 PM
jfarcas
Jul 14, 2007 09:33 AM
JBronco
1978 - 1996 Big Bronco
Jul 6, 2007 12:31 AM
Oleblue74
Aug 13, 2005 11:54 PM
tone100
1983 - 2012 Ranger & B-Series
Mar 24, 2004 02:29 PM
