Gauges Acting Funny?
Old Jul 10, 2007 | 12:13 PM
jfarcas's Avatar
jfarcas
Hey there, have an electrical question:
The gauges in the instrument cluster on my truck, '76 Supercab 2wd, have been acting funny, and I'm wondering what in the electrical system could be causing it -
The temp gauge, the oil pressure gauge, and gas gauge will intermittently slowly climb towards the top of their ranges at the same time. The voltmeter is the only gauge not affected by this weird what I call a "power spike." They eventually come back down and rest where they should, but I have no idea what could be causing this.
Anyone else?
Old Jul 10, 2007 | 12:40 PM
wick246's Avatar
wick246
I too have this problem only my oil pressure gauge doesn't seem to be affected, only my fuel and temp gauges climb. They stay that way for 1 to 2 minutes and then return to normal.
Old Jul 10, 2007 | 02:35 PM
Mil1ion's Avatar
Mil1ion
Remove the instrument cluster and clean all the connections...especially the ICVR that is attached to the back.
Your cluster is intermittently getting ground through thre wrong place throwing your gauges off.
Old Jul 10, 2007 | 04:45 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check the Read First:FAQ thread at the top of the 73-9 forum for instrument cluster repair info.
Old Jul 11, 2007 | 04:07 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
You also may have a defective IVCR aka CVR = Ford P/N >> D1AZ-10804-A
IVCR/Constant Voltage Regulator plugs into printed circuit board.
Old Jul 12, 2007 | 12:39 AM
Torque1st's Avatar
Torque1st
Posting Legend
Almost every CVR problem I have seen has been due to a bad ground at the tab. The CVR gets hot during operation and the plastic that surrounds the attachment screw deforms allowing the ground connection to come loose.
Old Jul 14, 2007 | 09:33 AM
jfarcas's Avatar
jfarcas
Thanks a bunch, guys...I'll pull the cluster tonight and check it out - it would make sense that it's the ICVR, too because it only happens after I've driven a while and things have generated heat.
90pioneer
Nov 18, 2013 02:11 AM
short stack
Apr 18, 2011 06:09 AM
snipa
May 21, 2008 08:08 AM
tmryan362
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 25, 2004 06:29 PM
T_Moss
Electrical Systems/Wiring
Oct 26, 2003 07:59 PM
