Am a bit
Old Apr 5, 2021 | 07:21 PM
seven-eight's Avatar
seven-eight
Am a bit
up agin er here
my beater farm truck (1978 F150 Custom, FWD, rebuilt 300 (maybe 50 feet on the motor))
plow truck that has slipped down a knoll side more than once, fitted out in Canada rusted out in Michigan, still I'd hate to scrap it
over a (maybe only one) rusted axle tube.
Not much luck on a specific ID of the Axle Housing Assy. (AHA) yet. Definitely non-removable carrier. The front cover shows
a history of removal. Was prepping to install new spring to axle U-joints and found pencil eraser size rust out hole in left axle tube, adjacent to U-bolt.
Right side not looking great either. Am yet to chisel around there. Entire frame checks out at a C minus IMO.
Remaining sheet metal (lost the bed a few years ago) in not bad shape.
Need some help to:
A. Know if the axle tubes are re-place able.
B. Know for certain (2 cents worth sought also) up or down on a weld fix.
C. I D's on any possible AHA sources (that I haven't scoured yet, (DVA has yet to get back to me)) for a used one.
Any assistance would be appreciated.
Tom
Old Apr 5, 2021 | 07:37 PM
redroad's Avatar
redroad
Is the hole in the axle tube actually where a vent used to be?
Have a look at the video It's an 84 Bronco Dana 44 but you'll see the location of where the vent should be.
Old Apr 5, 2021 | 07:55 PM
seven-eight
hello RR
Nope, not a rusted out vent hole.
I meant to write "U-bolt" twice in my thread.
The axle tube has a rust hole at the axle-U-bolt meet
(the bolt won, no rust there at all really, needed replace due to
rust wasted clamp part)
is that your ride with the bad *ss rear AHA?
Old Apr 5, 2021 | 08:06 PM
redroad's Avatar
redroad
BTW welcome to FTE
Wow that's the first time I heard of that happening. You're ealkimg about a HP Dana 44 made for coil springs, right?
Old Apr 5, 2021 | 08:23 PM
seven-eight
I have been lurking a while I guess
We like our salt up here
What I have gleaned so far (axle codes are not that informative IMO) is that this is a Ford AHA
Unless you are suggesting a Dana would fit ?
Old Apr 5, 2021 | 09:08 PM
redroad's Avatar
redroad
I guess I'm confused. It should have a Dana 44 HP coil spring front unless it's a super cab and a Ford 9" or a Dana 60 rear as far as I know?
Old Apr 5, 2021 | 09:14 PM
seven-eight
I don't know what it is other
than rear with leaf springs which
are connected to the axle tube via U-bolts
in the crevasse between the axle tube
and the U-bolt, throw in some salt
and you are going to get rust
Old Apr 5, 2021 | 09:23 PM
redroad's Avatar
redroad
1979 Ford F150 9". Does it look like that?
Old Apr 5, 2021 | 09:36 PM
seven-eight
No, that has a re-movable carrier.
Old Apr 5, 2021 | 09:47 PM
redroad's Avatar
redroad
Then it has to be a Dana 60. Is your truck a std. cab or super cab?
Figure out the gear ratio.
Are you in Mich.?
Old Apr 5, 2021 | 09:50 PM
seven-eight
std.
133" wheelbase
the axle tubes are 3" at the U-bolt
but narrower at the wheel flange.
Old Apr 5, 2021 | 09:52 PM
seven-eight
In Michigan, yes.
It's supposed to be 3.5 ratio
Old Apr 5, 2021 | 10:06 PM
redroad's Avatar
redroad
In Michigan, yes.
So any Ford Dana 60 rear !973-1979 with your gear ratio and accommodates a 3" wide spring should work. !973-1977.5 4wd std. cab F250's won't work as well as the F350's 1973-1979. Should be easy to find one. You need to nail down the gear ratio though.
Lived up in Benzie county for awhile.
Old Apr 5, 2021 | 10:12 PM
seven-eight
It's nice up there.
The springs are 3" true but I was speaking to axle tube dia.
You think it's a Dana?
Did they put Dana 60's on F150 rear?
Old Apr 5, 2021 | 10:23 PM
redroad's Avatar
redroad
It's nice up there.
On the super cab, crew cab, and some camper specials I believe. Your truck is 4wd, right? and if so does it have leaf or coil springs in the front?
