Am a bit
Old Apr 6, 2021 | 01:14 PM
  #31
seven-eight's Avatar
seven-eight
for rear:
S808A Bronco 84-86 3.55 8.8 NL
Old Apr 6, 2021 | 01:15 PM
  #32
seven-eight
Sorry, that is for the front. I am so confused....
Old Apr 6, 2021 | 01:17 PM
  #33
redroad's Avatar
redroad
Originally Posted by seven-eight
for rear:
We're going to have to call in the FTE CSI forensics team in on this one
Old Apr 6, 2021 | 01:26 PM
  #34
seven-eight
Rear is E4TW-A2A
I think that is a 1984 # right?
Somebody put 1978 body on a 1984 Bronco??
Old Apr 6, 2021 | 01:27 PM
  #35
symonds86's Avatar
symonds86
maybe they swapped axles in from a bronco?
Old Apr 6, 2021 | 01:31 PM
  #36
seven-eight
I need to go measure wheel base
  #37
redroad's Avatar
redroad
Rear is E4TW-A2A
If the front axle ID's as 80's then that's what I would conclude.
Old Apr 6, 2021 | 01:57 PM
  #38
seven-eight
WB is 133" which is what my layout book says is good for a version of 1978 F150 FWD.
Gotta search for WB of 1984 Bronco
Old Apr 6, 2021 | 02:00 PM
  #39
seven-eight
1984 Bronco is either 94 or 104 inches
Old Apr 7, 2021 | 10:40 PM
  #40
redroad's Avatar
redroad
Saw this today. Thought of you. Have a look. For $400. you get a matching set of axled Depends on how far your willing to drive.
Old Apr 8, 2021 | 06:49 AM
  #41
seven-eight
Thanks RR
I have been triple checking my frame
Dana 44's? Don't really know of them.
17 year old hound dog limits my travel these days.
I have been waiting to pull the trigger on a Dana 60
from da UP eh?
Old Apr 8, 2021 | 05:57 PM
  #42
seven-eight
again, just throwing a question or two out there
an ebay search returns:
77-79 FORD F100 F150 DANA 60 NON-REMOVEABLE CARRIER REAR AXLE 4.10 DIFFERENTIAL
(I don't know the rules here (don't want to get chewed out by RR) so I don't post an ebay link)
a pic of this, which should (per this description) fit my 1978 F150 1/2 ton shows:
(at a shop in Caspian MI, dang that's almost wisconsin, not that there's nothing wrong with wisconsin (whisky as we call it) except it's not shielded by a great lake, neither is the southwestern UP) but it gets COLD there)
notice the U-bolt groove marks on the axle tube, heck of a place to get rusty I'd bet.
anyway, what is that thing on the end of the axle tube?
It that gonna work on my 1/2 ton F150?
Old Apr 8, 2021 | 06:03 PM
  #43
redroad's Avatar
redroad
The distance between spring perches and the width of an individual spring perch are going to be the determining factor as well as the gear ratio of course.
Old Apr 8, 2021 | 06:15 PM
  #44
seven-eight
the width and location of the spring seat (I used to weld those on at Sterling Axle Plant (I think it's Ford's only axle plant but my dept. didn't do non-removable) are deal killers
unless I grind them off and have the pro down the re-weld them (I wasn't that great of a welder). Same for the shock mount.
Why do you stress the gear? It's a 4.10. I rode in a friends '70 Chevelle with a 4.11. I loved it. I try it, I don't like it, I swap it out.
But do I have to put doolies on? Not sure my compromised frame could handle that.
Old Apr 8, 2021 | 06:20 PM
  #45
seven-eight
A naturally torky 300 straight six with a moderately torky cam with a 4.0 gear. I think that would be a system.
