Bizarre start up issue with 2001 Excursion
Old Apr 2, 2021 | 08:12 PM
DerinSea's Avatar
DerinSea
I am currently having a weird issue with my 2001 Ford Excursion.
See, when I go to start up the truck initially for the day, I will turn the ignition over and it will take like a good 5 seconds to successfully turn over and start the engine. Then for the rest of the day, it will start up normally.
The thing is this problem occurs very randomly, like 1 out of 3 initial startups will be like this. I believe it might be a problem with the glow plugs, but I am unsure so i would like some thought from yall.
Everything else is good, alternator is good, fuel pump is new, batteries and cables are good.
Also if you need photos, just ask
Old Apr 2, 2021 | 09:00 PM
carbon coupe's Avatar
carbon coupe
Sounds like your LPOP is leaking down while sitting. May be time to replace it.
If you are getting a lot of fuel smoke on startup, that's the glow plugs not heating the charge.
Old Apr 2, 2021 | 09:51 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
It cranks for 5 seconds and then fires off, or there is a 5 second delay in the starter engaging to crank it?
Old Apr 2, 2021 | 11:56 PM
DerinSea's Avatar
DerinSea
I turn the key, it makes the sound of it trying to turn over, then it turns over.
Old Apr 3, 2021 | 12:02 AM
DerinSea's Avatar
DerinSea
I had not considered that. I have not noticed any smoke on startup.
Old Apr 3, 2021 | 12:03 AM
DerinSea's Avatar
DerinSea
I had not considered that. Also I have not noticed any smoke on start up.
hetmaster
Oct 13, 2012 07:12 PM
jo7.3idi
Dec 2, 2008 04:10 PM
Ztunamann
Apr 13, 2005 04:03 PM
DanAZ350
Jan 30, 2005 02:44 PM
mooner
Oct 9, 2002 08:48 AM
