Starting Problems
Old Oct 4, 2012 | 07:28 PM
hetmaster's Avatar
hetmaster
Starting Problems
I have a 1992 F-350 with a 7.3L engine I have replaced the batteries and had the generator tested good. I am still having a hard time getting my truck to start. I have even tried starting spray but that doesnt seem to do much. Please help
Old Oct 4, 2012 | 07:45 PM
81Bronk36's Avatar
81Bronk36
How fast does it turn over, shouldnt be able to see the fan spin, it should go so fast.
Either that or you have no compression
Old Oct 4, 2012 | 07:48 PM
hetmaster's Avatar
hetmaster
I turn the key wait for the wait light to go off and then it takes anywhere from 3 to 5 min to start
Old Oct 4, 2012 | 07:59 PM
81Bronk36's Avatar
81Bronk36
How do you even crank it for that long without blowing up your starter? Did it just start doing this or did you replace something? are your glow plugs even coming on? 3-5 minutes later and your plugs arent even warm either...
Old Oct 5, 2012 | 07:35 AM
hetmaster's Avatar
hetmaster
I dont crank it constantly for that long. The wait light comes on then goes out but I havent counted how long it stays on yet. The only thing I have replaced is the batteries. Its been doing this now for about a week or so. I have no idea if the glow plugs are even working. Is there a way to test them?
Old Oct 5, 2012 | 07:38 AM
bashby's Avatar
bashby
Read the glow plug sticky: https://www.ford-trucks.com/forums/9...le-system.html
Old Oct 13, 2012 | 10:06 AM
hetmaster's Avatar
hetmaster
I know this is not really the same topic but what voltage should the generator/ altenator put out when the truck is running?
Old Oct 13, 2012 | 12:15 PM
jeffbradbury7's Avatar
jeffbradbury7
my 1991 you have to crank it over 2-3 times for it to start. I think it is my fuel return lines on the injectors- they are old and cracked and letting air in the system
Old Oct 13, 2012 | 03:59 PM
tjc transport's Avatar
tjc transport
i ain't rite
here is a link to 2 starter videos. one bad, one good. the bad starter will just barely start the truck. the new one fires it rite off.
Ford Truck Enthusiasts Forums - View Single Post - Hard start cold, GP=good
Old Oct 13, 2012 | 07:12 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
3G alternator FACTS (its wins agian!) - FSB Forums
Nate Wengerd
May 28, 2019 09:36 PM
lexasgs400
Sep 10, 2007 11:39 AM
oldblue31
May 16, 2006 07:55 PM
Brandon_JH
Jun 16, 2002 01:14 PM
Yeti DHer
May 15, 2002 09:48 PM
