My early 99 has rear ABS and it activates too often. And when it does it seems like I lose 50% of my braking power. Which results in missing turns, and going for the shoulder when I actually need some flipping brakes....
What makes it decide to activate? It's only got the sensor on the rear differential. And isn't that for the speedometer?
Is there a way to disable it without the light on the dash coming on?
And Before anyone goes off on a " but you actually stop quicker with ABS" rant, no, it doesn't.
First, the ABS should help, not hurt. Get it inspected and tested to see what the problem is and get it fixed.
If you have no signal from a sensor, the ABS will not function, but your ABS will set the dash light and your regular brakes will still work as they should. You can always pull the bulb from the dash. I know of no other way to disable ABS.
BE CLEAR, though, I WILL NOT recommend running without ABS. Just saying! Get to the root cause and FIX the REAL problem.
Well of course nobody is going to recommend disabling ABS... but this F350 is the only vehicle I drive that even has ABS. So I'm pretty well versed in how to control a brake pedal.
I don't know what the problem is, or if there's even actually a problem. The brakes work perfectly, until ABS decides to kick in and take all the pressure off.
Come to think of it, i've never seen the light on the dash come on at all, even during start up. Is it supposed to?
With the key on but engine off, your dash should light up every light there, including ABS.
There was a lot of criticism of rear wheel ABS on early DRW trucks.
If you only have rear ABS you should be able to lock up the front wheels even when the braking in the rear is lost.
Can you lock up your front wheels?
If not, I would suggest having the whole system looked at, as you may not have front brakes at all!
I had a work truck with new rotors and calipers up front. Drove it a few days, then one day I had to stop short. Hhhhmmm, not much braking power. Did a little "test" when I got back to the barn. No fronts at all.
They fixed it overnight--what a difference. So it's possible to get used to a brake problem in normal driving.
A quick test in the parking lot at low speeds, I can get skid marks off all 4 tires.
And the ABS light does come on very briefly at start up. I guess I just never paid too much attention to it before. I had to turn the key on twice before I even found where it was lol
I do not however, have a parking brake light, at any time. Brake on or off.
I know what you mean, mine always did that and it was terrible, I pulled the ABS fuse and it works great now, been like that 3 years and I wish I would have done it sooner. The ABS light is on but it doesn't bother me.
It's stupid. The truck is nowhere near a skid and all of a sudden the brakes are gone.
I suppose it would be better if the truck was loaded all the time. But running around empty, it's not accurate at all.
I'd say you have a bad sensor , I had the same problem but in a 98 Chevy ,thought I was going to end up in a store front one . Pedal would drop to the floor and all you heard was the ABS kicking in. Pulled the fuse and now look at the light on the cluster, however pulling that fuse also lost my cruise control..
