Sponsored by: Auxito
abs
Old Aug 21, 2004 | 01:24 PM
nashr1's Avatar
nashr1
abs
I have a bad sensor on the right side front wheel and when it heats up the abs disengages causing a dangerout condition when the brake pedal drops about 2 inches then recovers to just normal brakes without abs. temporarily, if i would unplug the sensor upstream, would this disengage the abs all the time until i get the means to pull the rotor for replacement ? Or would it be easier to just pull the fuse for the abs ?
Old Aug 22, 2004 | 12:08 AM
Racerguy's Avatar
Racerguy
Anything you do that makes the ABS light on the dash stay on will disable the ABS.
As long as the light is on the brakes should work like normal old non-ABS brakes.
edsheridan
Aug 25, 2014 02:39 PM
mikulskn
Jun 26, 2013 11:23 PM
1sscav
1978 - 1996 Big Bronco
Sep 26, 2011 12:13 PM
Forced347sn95
1997 - 2003 F150
Nov 15, 2008 10:12 AM
edub32
53
Feb 5, 2006 09:05 AM
