A few paint questions
Old Feb 23, 2021 | 08:28 AM
vtpkrat2's Avatar
vtpkrat2
A normal process would be body work, as in repair dents,rust etc. When satisfied ,THEN primer (preferably an epoxy( catalized/hardened) primer. Sand & block all repairs and surfaces .Some will look great (there ! that spot done !) others will show needing more work or more priming and or blocking. When happy with all that process..... epoxy SEALER applied , (a barrier to keep topcoats from sinking,soaking like a sponge into bottom coats). Then your color coat..
Your sealer as an initial starting coat is not doing an awful lot down there.It is intended to SEAL solvents from topcoats (your color paint) from absorbing into the primer and bodywork. So.. 1) body work & primer,2)sealer,3) color -topcoats 4) stand back and look at what you accomplished !!
Old Feb 23, 2021 | 04:52 PM
scottscott's Avatar
scottscott
I spent some time looking at the TPC offerings today. I was hoping for more details about how they want their products to be used, but the info they provide is pretty basic.
Since you are taking it down to bare metal, & plan on using it as a driver, I would use the epoxy as the base. Then do your bodywork. Yes, you can put bondo over epoxy primer, many systems recommend doing that rather than bondo on bare metal. Then lay on a few coats of this product: https://tcpglobal.com/collections/au...to-1-mix-ratio Then lots of block sanding.
I think you'll be fine with the red you chose, MUCH better choice than silver! I see the paint comes already reduced, one thing I am not crazy about. I want to use a reducer tailored to the temperature I am spraying in, this pre reduced product doesn't allow that. I guess just don't paint when it is too hot or too cold. TPC doesn't give any guidelines as to what that ideal temp would be though. Since the paint comes reduced, you will need at least two gallons.
What you want to do is a huge project. I recommend starting off with one panel to learn how all the products work, & what techniques work best for you. Take the hood off, strip it, lay on some epoxy. Fix any damage, use the surfacer, block the hood for days. When you think it is straight enough, take a few days off, then spray a couple more rounds of surfacer, block it again. Apply 3 rounds of the Rally Red, stand back & admire your work. Looks bad? Take a week off, sand the hood with 400 to smooth out the bad spots, shoot more red. You'll get the hang of it. Then do a couple of panels at a time up to the final blocking, until the whole truck is done Then spray the whole deal red at one time.
You can do it all yourself, & get a very nice result. Take your time, watch the details, figure out how to correct or avoid screwups. Ask questions on this forum. Good luck & have fun.
Old Feb 23, 2021 | 08:24 PM
ss27gogeta's Avatar
ss27gogeta
Thanks for all your help i did not know it came already reduced it. I really dont like that either as it dose not give me a lot of freedom on when I can spray it. I believe you have to reduced summit racing paint correct? That might be a better option. was this the info you were looking for if you have not already found this sheet. I had to hunt around a bit to find this on There site.
File Type: pdf
vidaliaman
Paint & Bodywork
Aug 23, 2020 09:17 AM
drewduncan15
Mar 21, 2012 10:12 AM
rmalottwtes30
Paint & Bodywork
Jul 4, 2007 02:33 PM
dynamis5
2004 - 2008 F150
Mar 25, 2007 07:57 PM
RobbieC
Jul 25, 2001 08:28 AM
