AT IT AGAIN
Old Mar 11, 2021 | 08:59 AM
  #46
Stubbornazz's Avatar
Stubbornazz
Originally Posted by udsuth78
I don't remember if your truck is manual or auto, but if auto drop it into neutral next time it acts up to rule out the shifter before dropping coin on a new starter or beating your's beyond repair.
02 Ford Excursion 7.3L 4x4 Auto transmission. No chips or mods except the EBP delete.
OMG got my normal trans shifting back and my semi normal fuel mileage back after changing out my fan clutch last night.. WOOHOO
Old Mar 11, 2021 | 09:41 AM
  #47
SkySkiJason's Avatar
SkySkiJason
Why do you think that is related?
Old Mar 11, 2021 | 10:01 AM
  #48
Stubbornazz
Fan clutch was seized up which was causing constant resistance against the engine which in turn will consume more go go juice.
Dang it the stupid P1316 came back after 82 miles. Stating same cylinders and wastegate boost. Cleared it all and ran all test twice.. Nothing is coming back up.. This is definitely becoming confusing.
Old Mar 11, 2021 | 01:05 PM
  #49
Stubbornazz
So this makes absolutely no sense to me. As stated in last post I had the P1316 show up at 80 miles. Cleared it all, tested and was good. Now I've traveled 312 miles total and still no codes or pending codes. Truck is running good minus needing new front tires. This ever happened with anyone or am I the only one with a truck with a mind of its own?
Old Mar 11, 2021 | 04:33 PM
  #50
udsuth78's Avatar
udsuth78
Pretty sure every engine I've ever been around that's put on some years and miles have had their own personality.
Old Mar 11, 2021 | 05:13 PM
  #51
Stubbornazz
Well drove a total of 369 miles and stopped to take care of a fiber optic job and when I just went to start it the mystery P1316 was back. So think when I get home Monday I'll open passenger side up and check those injectors for shims and remove them. I know when I did rebuild the injectors I gauged all of them and the ones I did shim I verified that they weren't over .004 or less than .002. I'm just so confused is all. Very last resort is to buy new injectors when I have the money and just limp around until then. BLAH
Old Mar 11, 2021 | 05:40 PM
  #52
FinnishStroker's Avatar
FinnishStroker
I have shimmed 2 of my injectors to 0.12mm armature clearance.
That's .0047",with no codes and no hitting to the solenoids.
It was Swamps info sheet that said factory clearance can be up to .005"
Old Mar 11, 2021 | 05:57 PM
  #53
Stubbornazz
I'm just so done with it. I've been at this for a few months now and each time I think I've solved the problem it comes back or something new pops up.. I've owned this truck since 2016 and the only problems I've ever had was an injector failure, mystery oil leak on top and low exhaust backpressure sensor go out.. This is definitely testing me, especially when this is my only mode of transportation.
Old Mar 11, 2021 | 11:49 PM
  #54
Stubbornazz
Just a quick question, been researching on and off though the night on trying to figure this mess out. Could a faulty CPS cause these issues? Just last week while going down the interstate the engine sounded like it was starving for fuel and was jerking. Could these tell tell signs of P1316 ( P1271, P1275, P1277 and P1274) be a related issue of the CPS? Tonight when trying to leave a parking lot the truck would start, but as soon as I dropped into gear the RPMs would drop and it would stall. I'm just trying to figure this all out.
Old Mar 12, 2021 | 12:29 AM
  #55
FinnishStroker
CPS is inexpensive,you can try a new Motorcraft.
Most likely CPS not your problem.
My experience in CPS failure is that it leaves a specific code for CMP circuit or no codes at all.
Old Mar 12, 2021 | 06:13 AM
  #56
udsuth78's Avatar
udsuth78
Have you done a pcm reset yet? I was getting some weird codes and strange behavior after swapping IDM a month or so ago, did reset and it helped for sure.
Old Mar 12, 2021 | 07:11 AM
  #57
Stubbornazz
https://www.youtube.com/watch?v=hZAsoqmqhdM
No I haven't tried this yet. Guess I'll try it today at some point. It can't hurt . At this point if someone suggested hopping around on one foot and spell Ford backwards several times would fix it, I'd probably try it.
Old Mar 12, 2021 | 07:53 AM
  #58
udsuth78's Avatar
udsuth78
Don't know about the hopping on one leg stuff, but I've found that talking dirty to it sometimes helps.
Old Mar 12, 2021 | 08:11 AM
  #59
Stubbornazz
LMAOOOOO 🤣🤣🤣🤣
I definitely talk dirty to it, cuss it out and threaten it constantly lately. Constipated taking to diesel mechanic, but they will probably do or suggest everything I've done so far. Here is the list of what I've done since January.
Replaced injector cups
Replaced injector o-rings
Replaced IPR
Replaced ICP and Pigtail
Replaced Oil cooler
Replaced Exhaust Pressure sensor
Replaced MAP
Replace Turbo
Replaced Boost sensor (red/green vacuum tube assembly)
Replaced IDM
Replaced UVCH (twice)
Rebuilt Injectors
Replaced Pigtail for passenger UVCH
Done resistance test from solenoids, 42pin and IDM.
Swapped solenoids to see if codes would follow.
Buzz tested,, Demand tested and any other test I could do through FORScan.
And after doing all of this I'm still getting this stupid P1316 code. So if anyone has any ideas of what I might be missing I would be very much appreciative.
Old Mar 12, 2021 | 09:11 AM
  #60
udsuth78's Avatar
udsuth78
The only other potential causes listed for that PCM code I see are IDM relay faulty or PCM faulty.
